Yes.Found out it works when the inductor has value around 10mh. That seems a bit high as all the circuits I checked had the inductor in the 100uH range. This circuit is high-voltage/low current. Can this be why a high-ish inductor is needed?
| Thread starter | Similar threads | Forum | Replies | Date |
| P | Basic 'clap ON' switch. | Sensor Design & Implementation | 16 | |
| C | basic questions about soldering. Beginner | Technical Repair | 47 | |
| F | Basic Buck Converter Analog Control Circuit | Power Electronics | 2 | |
| M | basic buck converter question for input filtering | Power Electronics | 7 | |
| B | Buck converter module as basic PSU? | General Electronics Chat | 2 |
