Basic 555 Water Level Sensor - Is it safe for fish?
sghioto
Joined Dec 31, 2017
8,749
I knew it was a mute point but interesting in knowing that the 555 will trigger when Vcc is removed from pin 2 without a pull down resistor. Apparently the internal resistance of the input is sufficient. Verified using a LM555 in my test circuit.
bassbindevil
Joined Jan 23, 2014
924
National Semiconductor used to make the LM1830 level sensing chip, which put AC on the probes to eliminate the risk of plating. The chip is out of production, but there might be a way to achieve the same results using a microcontroller.
