Barrel Jack soldering locations
clangray
Joined Nov 4, 2018
261
For the barrel jack/PCB shown below: in soldering the Barrel Jack component, do I solder just the leads of the barrel jack or both the leads and the slots they are in?
MaxHeadRoom
Joined Jul 18, 2013
30,791
The single terminal at the bottom is the disconnect from the top terminal nearest the camera. When the plug is used to connect.
Not usually required.
MaxHeadRoom
Joined Jul 18, 2013
30,791
hi clan,
I usually solder all the tags, it gives a stronger hold for the connector to the PCB.
E
True, I generally place a sole pad for the purpose just to anchor it, if used on a P.C.
In the OP's case, it appears to be intended for discrete cable soldered connection ?
AnalogKid
Joined Aug 1, 2013
12,256
Nope. There are many variations of that jack type, and some have much wider tabs and/or slsightly different tab locations. The overly-elongated holes can accomodate a wider range of connector suppliers.
As above, fill all three hoes with solder.
ak
MaxHeadRoom
Joined Jul 18, 2013
30,791
Nope. There are many variations of that jack type, and some have much wider tabs. The overly-elongated holes can accomodate a wider range of connector suppliers.
ak
I intended to mean that the OP's P.C. board seems more intended for wire connection rather than the P.C. pad/trace connection.
