Band pass filter question
Saviour Muscat
Joined Sep 19, 2014
187
Hello all,
I have a simple task here but I am a little bit confused about amplifier characteristics when saying input impedance @1kHz 1Kohm,
Is it saying simply input of 1KHz signal with signal generator input impedance at 1Kohm?
TY
Saviour
WBahn
Joined Mar 31, 2012
33,322
It's saying that if you put your circuit in a black box with two input terminals sticking out and someone hooks up your circuit as the load to theirs, that at a frequency of 1 kHz it should look to them as if what was in that box was a simple impedance of 1 kΩ.
Saviour Muscat
Joined Sep 19, 2014
187
Please could you provide sketches to be sure that understood well your explanation because my diagram I think is wrong
Thank you again
Saviour
Papabravo
Joined Feb 24, 2006
22,115
Thank you again
Saviour
The diagram is correct, but you CANNOT measure it with a DC ohmmeter. It is an AC impeadance with a magnitude of 1KΩ. If you measure the impeadance at another frequency it might be the same or different.
MrAl
Joined Jun 17, 2014
13,862
Hello all,
TY
Saviour
Have you learned how to design filters like this using a Bode plot?
I mean an actual Bode plot as originally suggested by Bode not an actual frequency response curve.
That makes it a lot easier to select the values so i hope you did.
When the frequencies are this spread out that works really well.
Saviour Muscat
Joined Sep 19, 2014
187
Hi all,
sorry for the delay because I was at work today
I have drawn the bode plot(with Orcad because LTSpice doesn't have UA741, TL072, and TL082 library) as shown figures attached and I did the calculations to find R1, R2, C1, and C2 which are:1k,100k,7.95uF, and 0.1592nF respectively. Equations used
Z=1K=root(R1^2+XC1^2)@1KHz-----1
100=-R2/R1@40dB------2
wL=1/C1*R1@20Hz------3
wH=1/C2*R2@10KHz------4
I checked my results several times with different opamps and the best(TL072 figure1) results cames out that at Lower cutoff frequency (Figure2) the gain is about 37dB but at Higher cutoff frequency(figure3) at 10KHz the gain is about 36dB, the latter result is normal or cannot be accepted (-3dB)?
TY
Saviour
MrAl
Joined Jun 17, 2014
13,862
That looks good actually. If you went with more accurate values you would see more accurate results that's all. Ultimately this is still a bit of an approximation but it gets very close.
