BACnet sensor
Ian0
Joined Aug 7, 2020
13,278
There seems to be tons of information out there as to how to connect up BACnet and implement Building Managent systems, but almost nothing about how to make a sensor to connect to it.
So, I‘d like to design a device that can supply half a dozen analogue parameters and a few on/off binary levels.
What I know so far is that each is called an “object”, the system controller sends a UDP datagram to the sensor, and the sensor responds by sending the data that was requested as another UDP datagram.
And also, that if a parameter strays outside a set band, the sensor sends that data without being asked.
I’m guessing that one of those USRiot modules can handle the UDP datagrams, and all I have to do is decode the serial data, and send the reply.
Have I hugely underestimated what is involved? Any pointers to useful application notes, microcontroller software examples etc. would be much appreciated.
