HI,
What would be the best way to connect a back EMF diode to a PCB?
Would it be ok to connect it straight to the ground plane as in the first picture, or should I connect the 2 pins directly to each other and then connect to the ground plane with a 0ohm resistor (different net)?
Cheers,
Mike.
Ground Plane Connection
Connect to ground plane via 0ohm resistor
Cheers,
Mike.
