Did you have a current limiting resistor in series with the LED, say 470Ω ?I built program on atmega8 and i simulated it on proteus and it worked without coontecting any thing to the output of avr. When i connect the output as led. the microcontroller output go low and the led doesnt turn on. Where is the problem?
Yes,there is and i tried to put larger value resistance but it is still low. If you know proteus the outputs of microconyroller is highlighted when the output is high. In my case nothing work when i put loadDid you have a current limiting resistor in series with the LED, say 470Ω ?
Proteus is probably not going to care.Did you have a current limiting resistor in series with the LED, say 470Ω ?
There are several possibilities:I built program on atmega8 and i simulated it on proteus and it worked without coontecting any thing to the output of avr. When i connect the output as led. the microcontroller output go low and the led doesnt turn on. Where is the problem?
Project :
Date : 19/06/2017
Author : mado
chip type : ATmega8
Program type : Application
AVR Core Clock frequency: 8.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
#include <stdint.h>
#include <stdio.h>
#include <delay.h>
#include <stdlib.h>
#define DHT11 //define DHT22 or DHT11
#define DHT_PORT PORTC
#define DHT_DDR DDRC
#define DHT_PIN PINC
#define DHT_BIT 2
#define ADC_VREF_TYPE 0x00
#asm
.equ __lcd_port=0x12 //PORTD RS,RW,E
#endasm
// Alphanumeric LCD Module functions
#include <alcd.h>
// Read the AD conversion result
unsigned int read_adc(unsigned char adc_input)
ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
// Delay needed for the stabilization of the ADC input voltage
delay_us(10);
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
ADCSRA|=0x10;
return ADCW;
///////////// adc
float delta,adc;
char str[16]; //allocate on lcd
int currentValue ;
float Tref=36;
//// humidity and temp
unsigned char buff [16];
float h=0;
float t=0;
bit hum=0;
uint8_t data[5]={0,0,0,0,0};
int read_dht_hum()
unsigned char i,j;
//=============MCU send START
DHT_DDR|=(1<<DHT_BIT); //pin as output
DHT_PORT&=~(1<<DHT_BIT); //0
delay_ms(18);
DHT_PORT|=(1<<DHT_BIT); //1
DHT_DDR&=~(1<<DHT_BIT); //pin as input
//=============check DHT11 response
delay_us(50);
if (DHT_PIN&(1<<DHT_BIT))
return 0;
delay_us(80);
if (!(DHT_PIN&(1<<DHT_BIT)))
return 0;
//===============receive 40 data bits
while (DHT_PIN&(1<<DHT_BIT));
for (j=0; j<5; j++)
data[j]=0;
for(i=0; i<8; i++)
while (!(DHT_PIN&(1<<DHT_BIT)));
delay_us (30);
data[j]|=1<<(7-i);
return 1;
void dht_read()
hum=0;
#asm("cli")
hum = read_dht_hum();
#asm("sei")
if(hum==1)
#ifdef DHT22
h = (float) data[0] * 256 + data[1];
h = h/10;
t = (float) data[2] * 256 + data[3];
t = t/10;
#else
h = data[0];
t = data[2];
#endif
void pr()
dht_read();
lcd_gotoxy(0,1);
#ifdef DHT22
sprintf(buff,"DHT22 %.1f%C/%.1f%% ",t,h); //DHT22
#else
sprintf(buff,"H=%.1f%% ",h);//DHT11 //"T=%.1f C
#endif
lcd_puts(buff);
//////////////////////read temperature analog
currentValue = read_adc(0);
lcd_gotoxy(8,1);
lcd_putsf("T=");
lcd_gotoxy(10,1);
adc=currentValue*0.4887;// (500)/1023;
ftoa(adc,0x02, str);
lcd_puts(str);
lcd_gotoxy(14,1);
lcd_putchar(0xdf); //degree symbol
lcd_putsf("C");
// Timer 2 output compare interrupt service routine
interrupt [TIM2_COMP] void timer2_comp_isr(void)
// Place your code here
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
// External Interrupt 1 service routine
interrupt [EXT_INT1] void ext_int1_isr(void)
lcd_init(16);
lcd_clear();
lcd_gotoxy(5,1);
lcd_putsf("Tref=");
lcd_gotoxy(10,1);
ftoa(Tref,0x02, str);
lcd_puts(str);
lcd_gotoxy(14,1);
lcd_putsf("C");
Tref=Tref+0.1;
if(Tref>=38)
Tref=36;
delta=(adc-Tref);
delay_ms(1000);
void main(void)
PORTB=0x00;
DDRB=0xF0;
PORTC=0x;
DDRC=0xFF;
PORTD=0x00;
DDRD=0xE0;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock source: TOSC1 pin
// Clock value: PCK2/1024
// Mode: CTC top=OCR2
// OC2 output: Disconnected
ASSR=0x08;
TCCR2=0x0F;
TCNT2=0x00;
OCR2=0x20;
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: ANY CHANGE
// INT1: On
// INT1 Mode: ANY CHANGE
GICR|=0xC0;
MCUCR=0x00;
GIFR=0xC0;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x80;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// ADC initialization
// ADC Clock frequency: 1000.000 kHz
// ADC Voltage Reference: AREF pin
ADMUX=ADC_VREF_TYPE & 0xff;
ADCSRA=0x83;
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTD Bit 5
// RD - PORTD Bit 6
// EN - PORTD Bit 7
// D4 - PORTB Bit 2
// D5 - PORTB Bit 3
// D6 - PORTB Bit 4
// D7 - PORTB Bit 5
// Characters/line: 8
lcd_init(16);
lcd_clear();
// Global enable interrupts
#asm("sei")
while (1)
delta=(adc-Tref);
if ( adc >=Tref && delta>=0.3)//
PORTB.1=0; //turn heater off
else if (adc <=Tref && delta<=-0.3)//
PORTB.1=1 ; //turn heater on
if(adc<=35) //if temperature <35 alarm
PORTD.1=1; //alarm
else
PORTD.1=0; //alarm
pr();
Mystery solved! Consult the Atmel datasheet and you will find that you have onfigured PORTB.1 as a tri-state output. In this condition it cannot drive R3 which is connected to the base of the transistor.here is the code
and the proteus picture pin 15 (PB1) is high however , the relay is not activated. if i disconnected it it goes high as in the pictureC:/***************************************************** Project : Date : 19/06/2017 Author : mado chip type : ATmega8 Program type : Application AVR Core Clock frequency: 8.000000 MHz Memory model : Small External RAM size : 0 Data Stack size : 256 *****************************************************/ #include <mega8.h> #include <stdint.h> #include <stdio.h> #include <delay.h> #include <stdlib.h> #define DHT11 //define DHT22 or DHT11 #define DHT_PORT PORTC #define DHT_DDR DDRC #define DHT_PIN PINC #define DHT_BIT 2 #define ADC_VREF_TYPE 0x00 #asm .equ __lcd_port=0x12 //PORTD RS,RW,E #endasm // Alphanumeric LCD Module functions #include <alcd.h> // Read the AD conversion result unsigned int read_adc(unsigned char adc_input) { ADMUX=adc_input | (ADC_VREF_TYPE & 0xff); // Delay needed for the stabilization of the ADC input voltage delay_us(10); // Start the AD conversion ADCSRA|=0x40; // Wait for the AD conversion to complete while ((ADCSRA & 0x10)==0); ADCSRA|=0x10; return ADCW; } ///////////// adc float delta,adc; char str[16]; //allocate on lcd int currentValue ; float Tref=36; //// humidity and temp unsigned char buff [16]; float h=0; float t=0; bit hum=0; uint8_t data[5]={0,0,0,0,0}; ////////////////////////////////////////////////////////////////////////////////////////// int read_dht_hum() { unsigned char i,j; //=============MCU send START DHT_DDR|=(1<<DHT_BIT); //pin as output DHT_PORT&=~(1<<DHT_BIT); //0 delay_ms(18); DHT_PORT|=(1<<DHT_BIT); //1 DHT_DDR&=~(1<<DHT_BIT); //pin as input //=============check DHT11 response delay_us(50); if (DHT_PIN&(1<<DHT_BIT)) { return 0; } delay_us(80); if (!(DHT_PIN&(1<<DHT_BIT))) { return 0; } //===============receive 40 data bits while (DHT_PIN&(1<<DHT_BIT)); for (j=0; j<5; j++) { data[j]=0; for(i=0; i<8; i++) { while (!(DHT_PIN&(1<<DHT_BIT))); delay_us (30); if (DHT_PIN&(1<<DHT_BIT)) data[j]|=1<<(7-i); while (DHT_PIN&(1<<DHT_BIT)); } } return 1; } void dht_read() { hum=0; #asm("cli") hum = read_dht_hum(); #asm("sei") if(hum==1) { #ifdef DHT22 h = (float) data[0] * 256 + data[1]; h = h/10; t = (float) data[2] * 256 + data[3]; t = t/10; #else h = data[0]; t = data[2]; #endif } } void pr() { dht_read(); lcd_gotoxy(0,1); #ifdef DHT22 sprintf(buff,"DHT22 %.1f%C/%.1f%% ",t,h); //DHT22 #else sprintf(buff,"H=%.1f%% ",h);//DHT11 //"T=%.1f C #endif lcd_puts(buff); //////////////////////read temperature analog currentValue = read_adc(0); lcd_gotoxy(8,1); lcd_putsf("T="); lcd_gotoxy(10,1); adc=currentValue*0.4887;// (500)/1023; ftoa(adc,0x02, str); lcd_puts(str); lcd_gotoxy(14,1); lcd_putchar(0xdf); //degree symbol lcd_putsf("C"); } // Timer 2 output compare interrupt service routine interrupt [TIM2_COMP] void timer2_comp_isr(void) { // Place your code here } // External Interrupt 0 service routine interrupt [EXT_INT0] void ext_int0_isr(void) { } // External Interrupt 1 service routine interrupt [EXT_INT1] void ext_int1_isr(void) { lcd_init(16); lcd_clear(); lcd_gotoxy(5,1); lcd_putsf("Tref="); lcd_gotoxy(10,1); ftoa(Tref,0x02, str); lcd_puts(str); lcd_gotoxy(14,1); lcd_putchar(0xdf); //degree symbol lcd_putsf("C"); Tref=Tref+0.1; if(Tref>=38) { Tref=36; } delta=(adc-Tref); delay_ms(1000); } ///////////////////////////////// void main(void) { PORTB=0x00; DDRB=0xF0; PORTC=0x; DDRC=0xFF; PORTD=0x00; DDRD=0xE0; TCCR0=0x00; TCNT0=0x00; TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: TOSC1 pin // Clock value: PCK2/1024 // Mode: CTC top=OCR2 // OC2 output: Disconnected ASSR=0x08; TCCR2=0x0F; TCNT2=0x00; OCR2=0x20; // External Interrupt(s) initialization // INT0: On // INT0 Mode: ANY CHANGE // INT1: On // INT1 Mode: ANY CHANGE GICR|=0xC0; MCUCR=0x00; GIFR=0xC0; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x80; // USART initialization // USART disabled UCSRB=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; SFIOR=0x00; // SPI initialization // SPI disabled SPCR=0x00; // TWI initialization // TWI disabled TWCR=0x00; ////////////// // ADC initialization // ADC Clock frequency: 1000.000 kHz // ADC Voltage Reference: AREF pin ADMUX=ADC_VREF_TYPE & 0xff; ADCSRA=0x83; //////////////////// // Alphanumeric LCD initialization // Connections are specified in the // Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu: // RS - PORTD Bit 5 // RD - PORTD Bit 6 // EN - PORTD Bit 7 // D4 - PORTB Bit 2 // D5 - PORTB Bit 3 // D6 - PORTB Bit 4 // D7 - PORTB Bit 5 // Characters/line: 8 lcd_init(16); lcd_clear(); // Global enable interrupts #asm("sei") while (1) { delta=(adc-Tref); if ( adc >=Tref && delta>=0.3)// { PORTB.1=0; //turn heater off } else if (adc <=Tref && delta<=-0.3)// { PORTB.1=1 ; //turn heater on } if(adc<=35) //if temperature <35 alarm { PORTD.1=1; //alarm } else PORTD.1=0; //alarm pr(); } }
