Averaging two 0-5V analog signals #2
JR1029384756
Joined Sep 13, 2020
6
Sorry for replying to an old thread. I thought the subject was so similar it made sense to reply to the old thread. I am trying to average and not sum 2ea. 0-5v analog signals from 2 Mass Air Flow MAF sensors. The sensors have 3 wires in this case and not 4: Ground, 5v and signal back to the ECU. The ECU will be recalibrated for different airflow based on 2 MAFs versus 1 so that isn't an issue. Just wondering if the circuit suggested for the 4 wire MAFs could e used by just supplying 12v to the circuit from the ECu supply versus the MAF supply?
Thanks,
John
ericgibbs
Joined Jan 29, 2010
21,544
hi JR,
Welcome to AAC.
No problem re old thread, RonH has not been online here since 2016.
E
BTW: if you prefer a new Title for the Thread, post it and I will Edit.
JR1029384756
Joined Sep 13, 2020
6
Depends. Do the sensors require a 5 volt supply or a 12 volt supply?
SG
They take 5 volt supply. I was wondering if I could just take the proposed circuit and feed the LM358 from the 12v+ powering the ECU instead of the MAF as the drawing shows?
Thanks,
John
JR1029384756
Joined Sep 13, 2020
6
1 question what is the purpose of the 2nd LM358 just connected to the sensor ground? Other sensors use the same ground. Will it interfere with those?
Thanks,
John
