Audio Amplifier BJT Help!!!
ganny
Joined Feb 7, 2018
35
Hi, we were asked to make an audio amplifier using only bjt in net and build it could someone help me. I found a circuit but when I simulate it using proteus it doesnt have perfect wave as it supposedly. Heres the circuit diagram
ericgibbs
Joined Jan 29, 2010
21,631
hi,
Is the waveform at say, 10mV OK.
That image appears that you are over driving it.
If you have a link to that web page I will have a look.
E
ganny
Joined Feb 7, 2018
35
1mv pk to pk works fine... The output is 1v pk to pk.. anything much over 2mV is clipped..
Thanks for your response. Is there a good thing about it? Especially when the input signal is not that kind of amplitude correct me if I am wrong thanks
hi,
Read thru your link, will try it out using LTSpice, give me a little while, I will post back later.
E
Effort Appreciated. I'll wait for you
Ian Rogers
Joined Dec 12, 2012
1,136
Lets wait for Eric... If his results are the same as mine....
Yep!! But it seems now the fist stage is attenuating 20mV to 10mV.. Works better though..
ericgibbs
Joined Jan 29, 2010
21,631
hi,
Are you using the exact components as shown in the original drawing.???
It works perfectly well upto 30mV, with minimum cross over distortion.
E
Ian Rogers
Joined Dec 12, 2012
1,136
@ganny Change your 2n2222's to 2n2222a's and change all your caps to the cap-elec models..
Here's a screenshot of the three waveforms I get on Proteus.. Vey similar to Erics..
ganny
Joined Feb 7, 2018
35
Yes, I used the same components. I checked it many times
Is there difference between 2n2222 and 2n222a? Thanks
