Audio Amplifier BJT Help!!!
ericgibbs
Joined Jan 29, 2010
21,555
Could you find me alternative circuit on net that works well?
hi ganny,
I would like to help, please give me an idea of your specification and I will discuss it with you.
Regarding the results in LTSpice, I have been using LTS for over 10 years, running many circuits using the 2N2222.
All have worked in practical circuits giving results close to the simulation, so I have a high degree of confidence the the 2N2222 model.
I have no experience of Proteus
Eric
Ian Rogers
Joined Dec 12, 2012
1,136
Proteus works very well The circuit I have drawn and the one you have drawn seem to work as expected.
The 2n2222 model within Proteus is flawed.. The 2n2222a works as it should.. I expect the circuit being simulated by Granny isn't quite correct.. I can't see the connections in this pictures properly..
ganny
Joined Feb 7, 2018
35
Hi guys, Could you find me an audio amplifier made using transistor about 4W? I spent a lot for this project yet I have done nothing. Its hard to look for components. Make sure it is easy to look at stores around. Thank You
JoeJester
Joined Apr 26, 2005
4,390
Your only criteria is use transistors and build a 4 W amplifier? No criteria on the input signal?
No criteria on the total harmonic distortion?
bertus
Joined Apr 5, 2008
22,998
Hallo,
As you posted in homework help, are you not supposed to design an audio amplifier?
What you are asking is like making a copy of a given design and not your own design.
The book I posted in post #23 will give you good guidelines for designing an amplifier.
Bertus
ganny
Joined Feb 7, 2018
35
No criteria on the total distortion and even in the output signal. Yes its just a copy from internet it doesnt require own design
JoeJester
Joined Apr 26, 2005
4,390
You would have to design an amplifier to be capable of driving a 4W speaker. I'd say build a 2 or 3W amp.
Being it's an audio amp, you would want low distortion so the music or voice would be clear.
MrAl
Joined Jun 17, 2014
13,786
One of the big drawbacks to the original circuit was that it has only a 5v power supply.
That's not going to produce much power out. At most, and this is beyond what is really possible, if we divide that by 2 we get 2.5v and 2.5v and 8 ohms doesnt lead to much power. It's actually much less than that though because of transistor drops and resistor drops, etc., as well as a DC voltage to sine voltage conversion factor like around 70 percent or so. So the theoretical limit of output power is very low, typical maybe for headphones. For example, with a 12v supply and plus and minus 5.5v output zeroed at +6v, the factor is 0.71 or close to that.
