thats coolhere's how I setup my simulation using TINA. There is a free version at TI called TINA-TI
It changes time . and only will trigger to channel 1 Ac coupledIf you sync your oscilloscope with LINE, and that trace becomes stable ... it's a derivative of the line frequency. If it's time changing, the source is something else.
What I am saying about using the LINE trigger is that any stable signal is a derivative of the line frequency. That would point you to anything derived from the AC line.
This also brings up a point, you could trigger channel 2, with the scope connected to the input signal. Then, you can see if it's a derivative of the input signal.
I'm thinking your chasing down some other type of noise or oscillation.
Do you remember the V/cm you set?
You set that video to private. You'll have to make it public.
I'm thinking you might put a plug into the Power Amp In and then measure the output of the power amp to see if the oscillations or noise is present there.
Exactly where is that turd coming from its in everythingWell, we know it wasn't a derivitive of the 120 Hz square wave.
Where was the TDS scope measuring and where was the other TEK scope measuring?
We are looking for about an 11 kHz signal according to these photos I extracted.
11764 kHz according to the TEK scope
