Yea I get that but its my first circuit. I was thinking with regulators or chips, etc that something like that'd be possible.I don't think you really understand Ohm's Law. Voltage, current and resistance (load in this case) are related by the formula I = E/R, or variants E = IR and R = E/I.
If you have a power source with a fixed output voltage of 12 volts, then it will supply 1 amp only when it is loaded with 12 ohms. If it is loaded with 24 ohms, it will supply 0.5 amps. If it is loaded with 6 ohms, it will supply 2 amps.
If you have a power source with a fixed output current of 1 amp, then it will produce and output voltage of 12 volts when driving a 12 ohm load. When driving a 6 ohm load, it will output 6 volts, and when driving a 24 ohm load will develop 24 volts.
You can't have both at the same time. However, you can have a power supply that crosses over between constant voltage and constant current at set points. See AnalogKid's post #12.
