Hello all,
I`m currently doing a home project that involves Atmega16A microcontroller and a brushed DC motor. The aim is to drive the motor at different speeds using PWM.
I did all of the PWM code on the microcontroller and tested it with a plugged in motor. Works fine (turns from slow to fast as the duty cycle increases).
The catch is that when i change the brushed DC motor to another DC motor it doesnt turn at all.
The datasheet of the motor which is turning is : http://www.johnsonelectric.com/en/p...e-dc-motors/datasheets/PC200DG-020-metric.pdf
The datasheet of the motor which isnt turning is:
http://www.pololu.com/file/download/fa_130ra.pdf?file_id=0J11 (The FA-130RA-18100 one)
