Assistance with Transistor Voltage Amplifier
SmokeDarKnight
Joined Dec 2, 2013
4
I currently in my first stage of a BSC in Electrical & Electronic Engineering course at University and feel like i'm falling at the first hurdle. I completed an HNC in Electrical Engineering at College however this did not include for any Electrical Components.
I've been asked to Design a Two Stage Voltage Amplifier with a gain between 30 and 50. My idea is to Stage each stage one at a time and design 2 stages with a gain of 6 which if i've red the notes correctly is a gain of
Gain Total = Gain Stage 1 . Gain Stage 2 = 6 . 6 = 36
From what i have read the calculations for both stages are identical.
For the Collector Current i have chosen 1mA
My next instruction is to make Ve 10% of Vcc but i cannot find anything in my notes about calculating Vcc.
Am i missing something obvious? Any advice would be much appreciated.
Mike
Alec_t
Joined Sep 17, 2013
15,156
The calculations will be similar, but not identical. The input impedance of the second stage will have a loading effect on the output of the first stage.
You don't calculate it: it is the supply voltage for the amp, e.g. 9V from a PP3 battery. Perhaps you're thinking of Vc (the collector voltage)? You should choose a collector resistor such that in the amp quiescent state Vc is about half Vcc.
Is the specified gain for DC or AC signals?
SmokeDarKnight
Joined Dec 2, 2013
4
Hi Alec T
I will take that into consideration. Makes sense thanks. Its only with 10% of my final mark i think i may be putting too much into it if its only with 10%. First Report so not sure what to expect.
Its an AC signal.
Thank you for your reply much appreciated.
33,203
In most places, 10% is basically a letter grade. I don't know what the grades and scaling is like in Scotland. But if it's similar, then it's worth some effort on your part.
SmokeDarKnight
Joined Dec 2, 2013
4
I'll defiantly try to pass it at least, I have two to do First is Analogue and its the one im struggling with and the other is Digital which i found really easy but i guess the better i do in these the more chance i have in passing the exam.
Saying that however im of the feeling if i don't understand my report then im not going to be ready for the exam. I will most likely stick to the digital section of the exam although im aware there will be a minimum amout of analogue that will take up a chunk of the exam.
vk6zgo
Joined Jul 21, 2012
677
Ask yourself--Do you want to be an Electronics Engineer,or a "Digital" Engineer?:D
The other point is that if you don't know the Digital stuff quite as well as you think you do,it may be good to have something to fall back on.
5% for "trying",even if you don't get it right may also be a lifesaver!
SmokeDarKnight
Joined Dec 2, 2013
4
Hey vk6zgo, i've been asking myself that for a couple of weeks now. My digital report is amazing im so impressed with it, it took me no time at all. I feel secure in digital.
Im going to see how my reports go and the exam and make a decision after that. If things don't goto plan then i will ask for advice from the Uni. Perhaps i would be more suited for a computer based science. Although work is paying me through for the Electrical aspects they might have something else to say about that but i could always start funding it myself. Im already in my 30s and feel like if i give up on education or take a break i'll just mess it up and not return so i want to at least learn something.
If that makes any sense :/
