Assistance with MultiSIM Circuitry - RAM Logic
mfr1980
Joined Jul 13, 2019
5
Hello all! I am new to this website and would like to get some assistance creating a functional circuit. Below are the lab directions:
Overview: Understanding memory
Resources to consult: Digital Electronics: Principles and Applications, 8th Edition, Chapter 11
Instructions:
1. Using the HM6116A120 (2Kx8 ram) create an addressable RAM circuit and perform the following:
2. Choose several address locations (not 0) and write the inverse of the address as data to that location.
a. Address is 0110 Data should be 1001
3. Read the memory in the following order: Read location 0 (this should be 0), Read the first location you wrote to, capture screen data, read the second location you wrote to, capture screen, etc.
4. Describe operation of the circuit. Capture output of seven segment for max, min, and in between values.
I am stuck on step 2a. I have tried a number of different avenues on how to wire it and none of them have been successful. I will show all four avenues I took to accomplish this. Additionally, I did research both the 6116 RAM chip and the 74LS244N buffer. Still at a total loss here.
Layout 1 (General Feedback into the Address Inputs):
Issues: Lights flicker; Read/Write function does not make a difference; No inversion takes place; No real memory takes place.
Operation: Only adjusted the Address Inputs and the WE position to enable Read or Write mode.
Layout 2 (Addition of a Pull-Up Resistors):
Remedies: Removes the flickering.
Issues: Read/Write function appears to be responsive; No inversion takes place; No real memory takes place.
Operation: Adjusted the Address Inputs, Data Outputs, and WE control.
Layout 3 (Removal of Pull-Up Resistors; Addition of Buffers; Addition of Pull-Down Resistor)
Remedies: None.
Issues: No functionality.
Operation: Adjusted Address Inputs, Control Inputs, and Data Outputs.
Layout 4 (Removal of Pull-Down Resistor; Movement of Buffers; Initiating New Outputs):
Remedies: None.
Operation: Still working this version of the circuit.
Any assistance, advice or even a complete revamp of the circuitry would be greatly appreciated. I'm highly methodical so step-by-step explanations work best for me. I have been at this lab now for about three days and now its mind numbing to look at. Maybe I'm over thinking this project.
mfr1980
Joined Jul 13, 2019
5
I am using the table below. Only modes 2 and 4 are usable for this circuit.
The order I intend to use is:
1) Set an address
2) Read the address
3) Invert the address
4) Write the address
5) Read the stored address
I thought by using the buffers I would be able to invert the address.
dl324
Joined Mar 30, 2015
18,479
The order of operations isn't detailed enough. You appear to be having problems having a write occur. The device has some specific sequencing requirements to do a write (or read).
You said you read the SRAM datasheet. It gave you some specific signal timings to accomplish a write. This is from an SYC 6116 datasheet:
One show W# going LOW before CS# and the other reverses the order. In both cases, the write is performed when W# goes HIGH.
mfr1980
Joined Jul 13, 2019
5
Good morning! As I slept last night I came up with a new logic that might be more productive. Although testing it this morning, I see that I still have the flashing LEDs found in Layout One (above). I used individual inverters and turned my Data Output switch into a Data Input switch.
mfr1980
Joined Jul 13, 2019
5
This is the datasheet I found and it contradicts yours:
absf
Joined Dec 29, 2010
1,968
1) Set an address
2) Read the address
74xx244 is non-inverting buffers.
If you want to use inverting buffers, use 74xx240
Allen
absf
Joined Dec 29, 2010
1,968
You can replace the DIP switches and 8 inverters with a 74HC240. And use the OE# to control its outputs between tristate and inverter.
OE# = High (tristate) when reading from RAM
OE# = Low (inverting buffer) when writing to RAM.
Allen
dl324
Joined Mar 30, 2015
18,479
1) Set an address
2) Read the address
Give us the exact sequence you're using to accomplish these steps. In particular, give the sequencing of WE, CS, and OE.
