AS358 Lithium charger circuit
eyesee
Joined Oct 19, 2013
82
I have a commercial Lithium charger which uses a dual AS358M Op-Amp IC and is based on the circuit below. I am trying to understand how the charger functions and also how to adjust the charge rate?
ian field
Joined Oct 27, 2012
6,536
You might be better off not messing with a lithium charger unless you *REALLY* know what you're doing!
If you overcharge a lithium cell, it can vent with flaming gas - There has been a spate of serious house fires in the UK, mostly because of cheapskates jumping on the E-cigarette bandwagon and designing dodgy lithium chargers with no end of charge shut off!
eyesee
Joined Oct 19, 2013
82
I am familiar with the CC/CV charge termination method that most Lithium chargers use. I am just curious how the above circuit works as I have seen similar designs used in other commercial chargers. I presume one of the resistors will set the CC charge rate but not sure which one?
bertus
Joined Apr 5, 2008
22,956
None of the values is given in your drawing.
Also nothing is mentioned about the SMPS block.
At R2 it says current sensing.
eyesee
Joined Oct 19, 2013
82
The circuit is taken from a datasheet for the AS358 IC - it is a suggested design. I will try and measure exact component values and map out the circuit of the charger I have.
