I am constantly trying to figure out how to do things, I recently scraged a kit because I could not get a power connector to stay put log enough for me to solder it. The connector shattered when I tried to tighten the forceps, but soldering is a solved issue. My current thought for component retention is a quick dry glue with a syringe style applicator, the glue doesn't need to be permanent, just strong enough to hold a component still long enough to solder a lead or 2. What I'm asking for is recommendations for the glue, I plan on buying the syringe separately.
I'm probably going to make a solder sucker from scratch, as I think I can do it for under $20. First step is a foot activated vacuum generator.
I find some humor when the Chinese docs refer to soldering as welding.
