Array of Buttons vb.net
FroceMaster
Joined Jan 28, 2012
708
Hi
Got 42 buttons, and when any of them is pushed, the code should do the same,
I have collected them all in a Collection.
Dim DATOB As New Collection
Code:
Private Sub Form1_Load_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Me.BackColor = Color.LightGray
        Button49.BackColor = Color.AliceBlue
        Button50.BackColor = Color.Red
        Button51.BackColor = Color.Green
        Button52.BackColor = Color.Yellow
        DATOB.Add(Button1)
        DATOB.Add(Button2)
        DATOB.Add(Button3)
        DATOB.Add(Button4)
        DATOB.Add(Button5)
        DATOB.Add(Button6)
        DATOB.Add(Button7)
        DATOB.Add(Button8)
        DATOB.Add(Button9)
        DATOB.Add(Button10)
        DATOB.Add(Button11)
        DATOB.Add(Button12)
        DATOB.Add(Button13)
        DATOB.Add(Button14)
        DATOB.Add(Button15)
        DATOB.Add(Button16)
        DATOB.Add(Button17)
        DATOB.Add(Button18)
        DATOB.Add(Button19)
        DATOB.Add(Button20)
        DATOB.Add(Button21)
        DATOB.Add(Button22)
        DATOB.Add(Button23)
        DATOB.Add(Button24)
        DATOB.Add(Button25)
        DATOB.Add(Button26)
        DATOB.Add(Button27)
        DATOB.Add(Button28)
        DATOB.Add(Button29)
        DATOB.Add(Button30)
        DATOB.Add(Button31)
        DATOB.Add(Button32)
        DATOB.Add(Button33)
        DATOB.Add(Button34)
        DATOB.Add(Button35)
        DATOB.Add(Button36)
        DATOB.Add(Button37)
        DATOB.Add(Button38)
        DATOB.Add(Button39)
        DATOB.Add(Button40)
        DATOB.Add(Button41)
        DATOB.Add(Button42)
        clearbuttons()
        firstload()
    End Sub
When i push from 1 to 42 the code should run a SUB.
Code:
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
' HOW ?
    End Sub
Dont want to make 42 buttons subs.
Kermit2
Joined Feb 5, 2010
4,159
Have sub read a counter or toggle bit. If button is pressed 'set' the bit. Reset toggle bit in last statement of sub then return.
FroceMaster
Joined Jan 28, 2012
708
have found solution
Code:
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click, Button9.Click, Button8.Click, Button7.Click, Button6.Click, Button5.Click, Button42.Click, Button41.Click, Button40.Click, Button4.Click, Button39.Click, Button38.Click, Button37.Click, Button36.Click, Button35.Click, Button34.Click, Button33.Click, Button32.Click, Button31.Click, Button30.Click, Button3.Click, Button29.Click, Button28.Click, Button27.Click, Button26.Click, Button25.Click, Button24.Click, Button23.Click, Button22.Click, Button21.Click, Button20.Click, Button19.Click, Button18.Click, Button17.Click, Button16.Click, Button15.Click, Button14.Click, Button13.Click, Button12.Click, Button11.Click, Button10.Click, Button1.Click
        Dim btn As Button = DirectCast(sender, Button)
       'Do something  etc.....
    End Sub
