Are there no MOSFET SCRs?
hp1729
Joined Nov 23, 2015
2,304
Why are there no SCRs with a ground input trigger or MOSFET SCRs?
Is a negative voltage SCR half of a TRIAC? Never made separately?
hp1729
Joined Nov 23, 2015
2,304
The FET doesn't have a conduction path from gate to source. Only a capacitor.
Is that a bad thing?
An SCR with the input resistance of a MOSFET? Sounds good.
Evidently, there are:
https://www.ibiblio.org/kuphaldt/electricCircuits/Semi/SEMI_7.html
They are described at the end of the article. Also a quite good article on the subject of SCR's.
And yes you could use a TRAIC to switch a negative DC voltage. (You would have to provide a means of turning it off tho.)
\Link doesn't work. "RC5 not supported", or something like that. I have TLS enabled.
(edited to add ...)
ibiblio is difficult to navigate. Is that SCR thing under "projects". Searching is not intuitive.
GopherT
Joined Nov 23, 2012
8,009
(edited to add ...)
Just get a "sensitive gate" scr. Much lower trigger and hold currents.
hp1729
Joined Nov 23, 2015
2,304
Diodes go in the desired direction. On N channel devices the cathode goes toward the Drain. On P channel devices the cathode goes toward the Source.
I think the body diodes get in the way with the ones you have shown. Always on with a negative supply voltage.
I will have to include them. Thanks.
RichardO
Joined May 4, 2013
2,270
I suspect that IGBT's are winning out over SCR's and triacs. Dealing with the commutation issue can be a b****.
The same thing happened with bubble memory and CCD memory when dynamic RAM came in.
GopherT
Joined Nov 23, 2012
8,009
Aren't IGBT's just a BJT with a capacitve gate instead of a base? And they still have the intrinsic diode issue.
It is more like a darlington where the input side is a MOSFET and the output side is a BJT. ill have to draw it out when I have a minute to see if the body diode is an issue in the igbt.
