I was making a project of voice activated Arduino and I encountered this problem.
When I connect the HC-05 to Android and then say something (I'm using the AMR App), it recognizes my voice but the leds don't turn on.
I have connected a HC-05 in this fashion:
The code which I'm using is:
[String voice;
int
led1 = 2, //Connect LED 1 To Pin #2
led2 = 3, //Connect LED 2 To Pin #3
led3 = 4, //Connect LED 3 To Pin #4
led4 = 5, //Connect LED 4 To Pin #5
led5 = 6; //Connect LED 5 To Pin #6
//--------------------------Call A Function-------------------------------//
void allon(){
digitalWrite(led1, HIGH);
digitalWrite(led2, HIGH);
digitalWrite(led3, HIGH);
digitalWrite(led4, HIGH);
digitalWrite(led5, HIGH);
void alloff(){
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
digitalWrite(led5, LOW);
void setup() {
Serial.begin(9600);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
void loop() {
while (Serial.available()){ //Check if there is an available byte to read
delay(10); //Delay added to make thing stable
char c = Serial.read(); //Conduct a serial read
if (c == '#') {break;} //Exit the loop when the # is detected after the word
voice += c; //Shorthand for voice = voice + c
if (voice.length() > 0) {
Serial.println(voice);
//----------Control Multiple Pins/ LEDs----------//
if(voice == "*all on") {allon();} //Turn Off All Pins (Call Function)
else if(voice == "*all off"){alloff();} //Turn On All Pins (Call Function)
//----------Turn On One-By-One----------//
else if(voice == "*TV on") {digitalWrite(led1, HIGH);}
else if(voice == "*fan on") {digitalWrite(led2, HIGH);}
else if(voice == "*computer on") {digitalWrite(led3, HIGH);}
else if(voice == "*bedroom lights on") {digitalWrite(led4, HIGH);}
else if(voice == "*bathroom lights on") {digitalWrite(led5, HIGH);}
//----------Turn Off One-By-One----------//
else if(voice == "*TV off") {digitalWrite(led1, LOW);}
else if(voice == "*fan off") {digitalWrite(led2, LOW);}
else if(voice == "*computer off") {digitalWrite(led3, LOW);}
else if(voice == "*bedroom lights off") {digitalWrite(led4, LOW);}
else if(voice == "*bathroom lights off") {digitalWrite(led5, LOW);}
voice="";}} //Reset the variable after initiating]
[String voice;
int
void allon(){
void alloff(){
void setup() {
Serial.begin(9600);
void loop() {
