I want the curcuit befor arduino please. and code.//Do you offset voltage?Hello, I am doing a project of current measurement using the LEM LA 55-P ( hall effect sensor ) transducer which senses the strength of magnetic field produced by a current carrying conductor traveling through the hole of the sensor and outputs a linear milliamp output. I want to interface this sensor with an Arduino UNO but am not to certain about the code required. A little bit about the sensor, it can measure a primary current up to 50 Amps which will output 50 milliamps; I am going to have the output going to a 100ohm precision resistor so that 50mA max output will equal 5 volts; 50mA x 100 ohms = 5 volts. I want to then send this output to the Arduinos analog to digital converter, and have an LCD display wired to the Arduino, with a code stating that 5 volts input will display 50 Amps to the LCD, 1 volt will display 10 amps etc. basically every 0.1 Volt = 1 Amp. if anyone has any insight on how to go about writing this code it would be much appreciated, I don’t think it will be an overly complicated code but I have next to no experience with C++, Thanks for your help.
Mod: Link to old thread.E
https://forum.allaboutcircuits.com/threads/arduino-uno-unsure-about-coding.133382/post-1110925
