Hi i notice that when i try to use D13 in arduino nano as an input for my temperature sensor, it turns out that it is not able to have proper readout. it keep showing negative values and it does not respond despite touching the temperature sensor. But however when D12 or some other D pins in arduino nano is used, it is able to function properly.
may i know why is this so? and is there any possible ways for that specific D13 pin to work with the temperature sensor? because that pin or that particular position is an ideal pin for me to solder my temperature sensor to it, thus i wouldn't need to "reroute" or use longer wires to solder.
