Arduino HCSR04 Crack Measuring
AJIN NADH
Joined Dec 18, 2014
84
Hi all,
I used to detect the small crack on wall using HCSR04 Ultrasound sensor,
But i cant sense the crack , i only getting the Distance, how can i sense the crack separately
Regards,
Ajin nadh .v.a
DickCappels
Joined Aug 21, 2008
10,170
Not sure I understand exactly what you mean by "crack" (Crack in what material and what item, dimensions, etc.) and by "detect".
If you are finding the distance from the transducers to the crack, isn't that sensing it? <== Clearly, I don't understand the setup.
AJIN NADH
Joined Dec 18, 2014
84
Hi Sir,
Actually am doing a Rail Ultrasonic Flaw Detection System, but the flaw is not traced by the sensor, only the actual distance is getting....
ScottWang
Joined Aug 23, 2012
7,399
If I had to guess, the HCSR04 does not have the sensitivity to detect such a narrow change in distance.
HC-SR04 Ultrasonic Module:
The Ultrasonic module detects the distance of the closest object in front of the sensor (from 2 cm up to 400cm).
Since the TS has such request, so he got to rty it.
ErnieM
Joined Apr 24, 2011
8,377
It is doubtful that sensor can find a small crack in a wall. First you need to ping with a wavelength short enough to see the crack. Then the receiver mus be able to see that return echo as you now need to see two echos, fist from the start of the crack, and the next from the end of the crack. That receiver can only sense one return ping for each burst so it is unsuitable without modification.
If you have an oscilloscope you can probe the analog receive signal to see if there is anything you could possibly capture to detect the crack. You may have multiple echos as the signal bounces off the crack several times.
jpanhalt
Joined Jan 18, 2008
11,087
My guess is the author wants to detect the discontinuity in the metal rail. Ultrasonic testing is used for such purposes in non-destructive (maybe pre-destruction?) testing of aircraft and other things. Here's a general description: https://en.wikipedia.org/wiki/Ultrasonic_testing
Don't know if the particular device the OP has will do that type of testing though.
John
Alec_t
Joined Sep 17, 2013
14,313
The wavelength of the 40kHz ultrasound is ~0.85cm in air, so I doubt such a low frequency would be able to detect a crack unless its width were about that distance. A cracked rail would be highly dangerous long before the crack reached that size. Even to sense a crack 0.85cm wide, I think you would need the transducer(s) in contact with the rail, not >2cm from it. Also, I think you might have to sense the phase of an echo signal, which the HCSR04 may or may not do.
John P
Joined Oct 14, 2008
2,026
This seems like a woeful misapplication of technology. An ultrasonic rangefinder operates at 40 KHz or so, but ultrasonic testing of solids uses frequencies into the megaHertz range, and requires contact with the material being tested. The WIkipedia article says "In most common UT [Ultrasonic Testing] applications, very short ultrasonic pulse-waves with center frequencies ranging from 0.1-15 MHz, and occasionally up to 50 MHz, are transmitted into materials to detect internal flaws or to characterize materials." A rangefinder will tell you how far it is from the sample, and that's all.
AJIN NADH
Joined Dec 18, 2014
84
Yesterday i tried the testing as the image shows ,
i placed the end very close to the track and found that a high value (am measuring the distance in cm), when the Flaw found.
ScottWang
Joined Aug 23, 2012
7,399
You have to comparing the values of flat wall and flaw wall, if the flaw is too small, I don't think it will works properly, because the distance of two components are too far.
mkbutan
Joined Sep 30, 2008
299
Hi dear all,
The Ultrasonic ranging module HC - SR04 provides 2cm - 400cm non-contact measurement function, the ranging accuracy can reach to 3mm (i.e. 0.3 cm)
Using IO trigger for at least 10us high level signal,
The Module automatically sends eight 40 kHz and detect whether there is a pulse signal back...
Electric Parameter
Working Voltage-----------------------DC 5 V
Working Current-----------------------15mA
Working Frequency-------------------40Hz
Max Range------------------------------4m
Min Range------------------------------2cm
Measuring Angle----------------------15 degree
Trigger Input Signal------------------10uS TTL pulse
Echo Output Signal Input-----------TTL lever signal and the range in proportion
now as per your Design http://forum.allaboutcircuits.com/threads/arduino-hcsr04-crack-measuring.120902/#post-965902
the main thing is your Moving Speed the Stationary parameters is (as per the datasheet) is 10μs ( Trigger Input Signal------------------10uS TTL pulse ) and that to at an Angel of 15°
so now you have to adjust your Speed to DETECT the CRACK in the RAIL
I thing that should solve the problem
ScottWang
Joined Aug 23, 2012
7,399
Ok sir,
is this will miss behave because of this cone shape ?
i will try it and revert back to u sir
If this method didn't works then you have to adjust the angles of two pipes, when you try it at many angles, but it still didn't works as your wish then you need to take the transmitter and receiver away from the pcb and put their direction as cone, you have to make sure they have a small angles maybe 10~20° between them, you need to adjust the angle to check which angle has the best effective.
AJIN NADH
Joined Dec 18, 2014
84
Hi dear all,
Sir,
This is the code actually am using
C:
HC-SR04 Ping distance sensor]
VCC to arduino 5v GND to arduino GND
Echo to Arduino pin 13 Trig to Arduino pin 12
Red POS to Arduino pin 11
Green POS to Arduino pin 10
560 ohm resistor to both LED NEG and GRD power rail
More info at: [URL]http://goo.gl/kJ8Gl[/URL]
Original code improvements to the Ping sketch sourced from Trollmaker.com
Some code and wiring inspired by [URL]http://en.wikiversity.org/wiki/User:Dstaub/robotcar[/URL]
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
void setup() {
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(led, OUTPUT);
  pinMode(led2, OUTPUT);
void loop() {
  long duration, distance;
  digitalWrite(trigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(trigPin, HIGH);
//  delayMicroseconds(1000); - Removed this line
  delayMicroseconds(10); // Added this line
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  if (distance < 4) {  // This is where the LED On/Off happens
  digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
  digitalWrite(led2,LOW);
  else {
  digitalWrite(led,LOW);
  digitalWrite(led2,HIGH);
  if (distance >= 200 || distance <= 0){
  Serial.println("Out of range");
  else {
  Serial.print(distance);
  Serial.println(" cm");
  delay(500);
Mod edit: Please use CODE tags - available on the post edit toolbar as Insert->Code Tags
