Arduino fails to restart sketch after power cycle
Fred Lewis
Joined Feb 23, 2017
5
When the sketch#1 is uploaded, it WILL NOT restart after a power cycle and must be reloaded.
When the Blink program from the built in examples is uploaded it WILL restart after a power cycle.
When the ReadAnalogueVoltage from the built in examples is uploaded it WILL NOT restart after a power cycle.
Sketch #1
-drives a sensor which communicates with Micro#1 via I2C on pins 2 and 3
-drives Xbee#1 which communicates with Micro#1 on pins 5 and MOSI
Xbee#1 is paired with Xbee#2 on another breadboard on which also sits Micro #2 and an LCD for output. Xbee#2 uses pins 3 and MOSI to communicate with Micro#2.
Sketch#2 restarts properly in Micro#2.
When Micro#1 and Micro#2 are swapped and sketch#1 loaded in Micro#2 the situation is the same, ie sketch#1 WILL NOT restart.
Saving this annoying situation, the whole thing works well. Valid data is acquired by the sensor, sent properly from one Xbee to the other and is accurately displayed on the LCD.
It cannot be (at least I don't think it can be)
-a fault on either bootloader
-a fault on either Micro
-unlikely to be RFI or other EMI interfering with the bootloader restarting the sketch as the Blink program does restart
I must find out what is going on before I start shooting in the dark.
HERE IS THE CODE FOR SKETCH#1
Code:
/****SKETCH_DAremoteDriver
READS BME280, CALCULATES DA, SENDS DATA TO COORD. XBEE****/
#include <SoftwareSerial.h>
#include <Wire.h>
#include <math.h>
#include <cactus_io_BME280_I2C.h>
const float c0 = 6.1078;           //constants for satVapourPress
const float c1 = 7.5;
const float c2 = 237.3;
const float RdryAir = 286.9;       // gas constant for dry air J/kg K
const float RwaterVapour = 461.5;  // gas constant for water vapour J/kg K
const float dA1 = 44.3308;         // constants for densityAlt
const float dA2 = 42.2665;
const float dA3 = 0.234969;
const float kmToFt = 3280.0;        // converts km to feet
const float cToK = 273.15;          // converts *C to *K
const float mbToPasc = 100;         // converts millibars to pascals
const int Rx = 16; //the micro can't use pin 2 for Rx
const int Tx = 5;
float satVapPress;        // saturation vapour pressure mb
float parPressWatVap;     // partial pressure of water vapour mb
float parPressDryAir;     // partial pressure of dry air mb
float airDensity;         // air density kg/m3
float densityAlt;         // density altitude in feet
float tempVar1;           // temporary variables for long equations
float tempVar2;
float temperature;        // sensor temperature value
float rh;                 // sensor relative humidity value
float pressure;           // sensor pressure value
int tempDA;
/****SO THAT END POINT XBEE 2 BYTE DATA CAN BE SENT AND REASSEMBLED AT COORDINATOR XBEE****/
int LSBtempDA;
int MSBtempDA;
int LSBpressure;
int MSBpressure;
int divisor = 256;
int rhInt;
int temperatureInt;
int pressureInt;
SoftwareSerial xbee(Rx, Tx);
BME280_I2C bme;           // Create BME280 object I2C using address 0x77
void setup()
    //delay(5000);
    //pinMode(2, INPUT_PULLUP);
    Serial.begin(9600);
    while (!Serial);   //because it takes a while to make the serial connection which is why println would not display
    xbee.begin(9600);
    Serial.println("Bosch BME280 Pressure - Humidity - Temp Sensor | cactus.io");
    if (!bme.begin())
       Serial.println("Could not find a valid BME280 sensor, check wiring!");
       while (1);
       //pins A4 (SCK) and A5 (SDA), used for I2C on the Uno are pins 2 (SDA) and 3 (SCL) on the micro
    bme.setTempCal(-0.5);        // Temp was very close so subtract 0 degree
    Serial.println("Pressure\tHumdity\t\tTemp\t\tsatVapPress\tparPressWatVap\tparPressDryAir\tairDensity\tdensityAlt");
void loop()
    bme.readSensor();
    temperature = bme.getTemperature_C();
    pressure = bme.getPressure_MB();
    rh = bme.getHumidity();
    satVapPress = c0 * pow(10, (c1 * temperature) / (c2 + temperature));   //calculate water vapour saturation pressure
    parPressWatVap = satVapPress  * rh / 100;                              //calculate water vapour partial pressure
    parPressDryAir = pressure - parPressWatVap;                            //calculate dry air partial pressure
    tempVar1 = parPressDryAir * mbToPasc / (RdryAir * (temperature + cToK));          //first term of airDensity
    tempVar2 =  parPressWatVap * mbToPasc / (RwaterVapour * (temperature + cToK));    //second term of airDensity
    airDensity = tempVar1 + tempVar2;                                                 //calculate air density
    int densityAlt = round((dA1 - dA2 * pow(airDensity, dA3)) * kmToFt);   //calculate density altitude in feet
    Serial.print(pressure); Serial.print(" mb\t");
    Serial.print(rh); Serial.print(" %\t\t");
    Serial.print(temperature); Serial.print(" *C\t");
    Serial.print(satVapPress);  Serial.print(" mb\t");
    Serial.print(parPressWatVap);  Serial.print(" mb\t\t");
    Serial.print(parPressDryAir);  Serial.print(" mb\t");
    Serial.print(airDensity);  Serial.print(" kg/m3\t");
    Serial.print(densityAlt);  Serial.println(" ft");
    tempDA = abs(densityAlt);
    /****Each call sends 3 bytes to coordinator xbee packing its read buffer with 12 bytes.***/
    DisassembleSendData(densityAlt);
    DisassembleSendData(temperature);
    DisassembleSendData(pressure);
    DisassembleSendData(rh);
    delay(4000);    // Add a 4 second delay
void DisassembleSendData (float dataToDisassemble)
  int tempVar;
  int LSB;
  int MSB;
  int divisor = 256;
  /***Disassembles sensor data into 3 bytes***/
  tempVar = dataToDisassemble;
  LSB = tempVar % divisor;
  MSB = (tempVar - LSB) / divisor;
  /***Sends 2 bytes to coordinator xbee read buffer***/
  xbee.write(LSB);
  xbee.write(MSB);
HERE IS THE CODE FOR SKETCH#2
Code:
/****This drives the Coordinator Xbee.  It receives data from the Remote Xbee, conditions it
and presents it for output.****/
#include <LiquidCrystal.h>
SoftwareSerial xbee(16, 3); //Rx TX
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int temperature;
int rh;
int pressure;
char c;
int densAlt;
int LSB;
int MSB;
int fractionalPart;
int LSBpressure;
int MSBpressure;
int divisor = 256;
int counter = 0;
char units;
void setup()
  Serial.begin(9600);
  xbee.begin(9600);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  Serial.println("hi fred");
  Serial.print("in setup");
  //lcd.print("hello, world!xxx");
void loop()
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 0);
  if (xbee.available() >= 8)
    //Density altitude data
    //fractionalPart = xbee.read();
    LSB = xbee.read();
    MSB = xbee.read();
    units = 'f';
    //AssemblePrintData(fractionalPart, LSB, MSB, units);
    AssemblePrintData(LSB, MSB, units);
    //Temperature data
    LSB = xbee.read();
    MSB = xbee.read();
    units = 'C';
    lcd.setCursor(0, 1);
    //Pressure data
    LSB = xbee.read();
    MSB = xbee.read();
    units = 'm';
    //Relative humidity data
    LSB = xbee.read();
    MSB = xbee.read();
    units = '%';
  //Serial.println("out of if");
void AssemblePrintData(int LSB, int MSB, char units) //(int xbee.read(), int xbee.read(), int xbee.read()) ???
  lcd.print((MSB * divisor + LSB)); /*lcd.print("."); lcd.print(abs(fractionalPart));*/ lcd.print(units); lcd.print(" ");
  Serial.print((MSB * divisor + LSB));/* Serial.print("."); Serial.print(abs(fractionalPart));*/ Serial.println();
Papabravo
Joined Feb 24, 2006
22,115
After a power cycle the Arduino goes back to the boot loader. It can't return to your program which may or may not be there depending on where it was stored. In order for you to get the behavior you want, the program has to be in Flash memory and the bootloader must be disabled. Once you do that you have to jump through some hoops to re-enable the bootloader.
Fred Lewis
Joined Feb 23, 2017
5
Why then, do both the Blink program and Sketch#2 restart after the power has been removed and restored?
djsfantasi
Joined Apr 11, 2010
9,237
How do you know that the sketch doesn't restart? I mean, the specific behavior may present a clue.
I don't have an explanation, but initializing the xbee object outside of the setup routine looks strange to me.
Fred Lewis
Joined Feb 23, 2017
5
If there is no output to the screen, I assume the sketch is not running. All of my programs have their objects initialized before the setup() routine and it has never been a problem.
Papabravo
Joined Feb 24, 2006
22,115
I guess we have a mystery here. It has been a while since I worked with the Duemille Nove, so I'm not able to offer more insight. You're closer to the problem than I am, so why do you think this is happening?
djsfantasi
Joined Apr 11, 2010
9,237
And I have tried to initialize objects outside the setup() routine, and it doesn't always work. I guess we're both right.
Fred Lewis
Joined Feb 23, 2017
5
Actually, I have a Micro, the same chip as the Leonardo. I am out of theories as to why it doesn't work. I need some likely cause of the difficulty before I start randomly attempting fixes.
