Arduino AC Meter Design LM358
meth
Joined May 21, 2016
324
OK Mr. Danger, mathematically all is safe with those resistors, but for any failure here (it doesnt have to be a failure of a component during regular work, maybe you will drop a screw inside during testing or sth like that) I would not like to wait for the 16A circuit breaker in the wall to drop, I would like 250mA fuse to disconnect right there.
schmitt trigger
Joined Jul 12, 2010
2,273
It looks like the peak voltage at the non-inverting input is less than +/-0.3 V
ak
Got it, it won’t damage the opamp.
But without a negative supply, it will still clip the negative excursions. The result is that only a half wave will be sampled.
He either needs to add a virtual ground or a charge pump to generate the negative supply.
AnalogKid
Joined Aug 1, 2013
12,287
We still don't know why he is sampling the mains voltage, so it might not be an issue. If all he wants is a peak value to turn into an quasi-RMS value for display, half-wave rectification of any kind should be ok.
ak
