MaxHeadRoom
- Joined Jul 18, 2013
- 30,885
You should see what I can do with five loaves and seven fishes!Give me a call when you're able to turn water into wine...![]()
Max.
Max.
Years ago I found a simple solution to making chess pieces. Not learn to play chess!I think I already posted this somewhere else, but what the heck... About 20 years ago I decided to design and build my own chess set. And it tested my wife's patience because she said that I was dedicating more time to that thing than to her... which was actually true... but in the end even she had to admit that it was worth it and liked the result.
I designed the pieces myself and drew them in AutoCAD. Then I searched for the perfect wood type for each color and decided on hickory for the dark pieces, and bird's-eye maple for the light ones. I actually had to make the material myself because I couldn't find anything in the market resembling what I wanted. Each layer of the finished pieces was actually cut in a CNC router (which I also designed and built myself) from wood sheets formed by gluing together five layers of veneer alternated at 90°. The sheet ended up being about 3/32" thick.
The last part involved making lots of tests mixing and using different types of wood stains until I got the antique effect that I wanted.
The board is made from leather, but I'm not the one who made it. I bought it for about $80 dlls during a trip to Paris with my wife in 1995... I bought the board back then even before conceptualizing the pieces, but avoided buying the pieces on purpose so as to feel more motivated later on to build them myself... and it worked.![]()
[after playing out all possible outcomes for Global Thermonuclear War]Years ago I found a simple solution to making chess pieces. Not learn to play chess!
Also found that solution solved a lot of other issues in life too.![]()
You have probably already seen this. My go to data base for wood species. http://www.wood-database.com/european-larch/ In the common uses area it mentions boat building.Hi.
Have anyone worked with the Siberian larch? Larix sibirica. And if so, how is it compared to pine, oak or teak. I'm playing with the thought of making some cleats for my boat in this type of wood.
No surprise. My first thought was, "I couldn't do that in a 40 hour week."It took me about three months,
When she first asked, I just "forgot" about it. She then called me four months before I was scheduled to visit and asked me if I had finished the bed. I said, "Ahh, ahh, ahh... Almost!" and got my butt in gear to buy all the parts and wood and get' er done!No surprise. My first thought was, "I couldn't do that in a 40 hour week."![]()
Perhaps, but I've read that you can have it as cladding (Is that the right word? I used Google translate...) on your house, and then I thought "Hmmm, can I use it on my boat?" As @shortbus says in his post, it's been used on boats.Isn't that classed as a softwood, compared to the traditional teak hardwood?
Max.
Wow!My sister asked me if I could make her a Murphy bed. I said that I could. It took me about three months, but I got the job done. Absolutely no plywood was used - solid red oak throughout. Photos aren't that great because of bad lighting and bad camera!
According the the data base, it is a 'soft' wood but what makes it different from most is that it has a pretty much even early and late wood ratio. The late wood or summer wood is denser and harder than early or winter wood. In wood the closer the ratio of the two types makes it both more stable and less wear prone. Generally the early wood is the darker colored "grain' in a board.Sitka Spruce is usually the prefered for spars, I made a sailboat boom out of it, beautiful with absolutely no knots.
Max.
Nice! Were all the pieces from places like Home Depot? You must have spent a lot of time sorting boards. That's always my least favorite part of a project.Absolutely no plywood was used - solid red oak throughout.
Curious - the bed appears to be made up with the head away from the woodwork. Is that typical? I would probably do it the other way but I've never had a Murphy bed.
Lemme give you a hint: Add a tablespoon of mineral spirits to 8 ounces of polyurethane to get it to strike into the wood instead of floating on top of the wood. It makes the grain show up more.(standardized on urethane now, easier than lacquer).
