Any real expert in HVAC here ?
Externet
Joined Nov 29, 2005
2,680
Hi all.
Looking for someone to give me light if a ~2Ton (24KBTU) duct-less heat pump for heating-ventilation-and-cooling exists; a single outside unit and 4 or 5 tiny indoor room units that install under existing floor registers.
No 'cassettes', nothing on ceilings, nothing on walls, no wifis, no remotes, no air ducts, no inverters, no Alexas, no 'smart' complications;
just refrigerant pipes/hoses/lines to run to each unit by crawling space/basement. :rolleyes:
Outside unit ===============================room1========room2========room3========room4
atferrari
Joined Jan 6, 2004
5,031
A member living in Miami was probably the most experienced on that matter.
IIRC, he was who started that thread about weather, many years ago.
38,909
Daikin makes AC units with multiple condenser outlets.
They show one that can go in a ceiling vent (below), but I assume it could also be put under the floor.
Futurist
Joined Apr 8, 2025
950
Hi all.
Are you asking a question? because I read your post twice and don't see one.
