Any US based PCB suggestions?
I think the main point here is "good enough" is often good enough.
One thing I have noticed about OSH Park and similar boards is durability. I've been able to rework several prototype boards with chip swaps and other improvments with no visible or operational damage on high quality US boards. Most of the default substrate and finish option on inexpensive Chinese boards I've used are OK for the initial install of fine-lead parts but rework makes them unreliable due to low temperature substrates deforming/charring, lines lifting and solder mask degradation.
trebla
Joined Jun 29, 2019
599
Most of the default substrate and finish option inexpensive Chinese boards I've used are OK for the initial install of fine-lead parts but rework makes them unreliable due to low temperature substrates deforming/charring, lines lifting and solder mask degradation.
Same experience here.
