Any one no where I can find these thermal cut out awitched off a comdemsor dryer
Hornet2121
Joined Jan 20, 2019
18
I have 2 cut out switches needing replacedon my dryer.
They dont sell replacments in a kit
Am just wondering does anyone ni where I can buy replacments or equivalent types that would fit.
It says on first one
261/p 16(3)250 T175k
On the side 120 degrees 39-13
2nd one Says
261/p 16(3)250 T175k 160 degrees 45-13
Hornet2121
Joined Jan 20, 2019
18
Iv searched cant find them they dont do a cit out kit but am sure I will be able to find these some where just cant find any on ebay.
Hornet2121
Joined Jan 20, 2019
18
I have no idea if they will work I think it may work for the 120 degree one.they dont go up to 160 degrees tho for the 2nd one.
I have no idea what amp I need
Can anyone exsplain all the symbols and words on the cut off switches.
Thanks for that link hopefully some one can confirm its the same type before I buy it.
27,443
There is a manufacturers logo on each one of those devices, and so you should be able to find a source of that brand. Also note that the one with the button is resettable, the others will switch back on as they cool.
AND, nobody would sell them as a kit. You need to select each one to purchase it. Most appliance parts shops can sell you those parts, although you should avoid the shops that also sell new appliances because they are not in the business of being able to repair anything.
How do you know that the devices need to be replaced?
Hornet2121
Joined Jan 20, 2019
18
Iv tested the eliment for continuity and by passed the switches with a wire and element heated uo glowed bright so am am guessing thats the issue
Funny cause I got 2 ohms on the multi meter and am sure that means they working.
Both had continuity.
Hornet2121
Joined Jan 20, 2019
18
No schamatics max
Would of been alot easyer
Any one no what amp these cut out switches are?
Seem some 10amp ones but unsure what amp mine are.
Hornet2121
Joined Jan 20, 2019
18
Iv tested the eliment and its reading 104 ohms so gona replace it as I believe its ment to be about 50 ohms
Thanks for help every one
