Any good ideas for a monophonic keyboard for synth
Surgent Gaming
Joined Feb 26, 2018
I am trying to build a monophonic synthesizer. The big problem I'm having now is that I have a keyboard and I want it to output a single note CV and gate. I have tried using resistors, but if you press two keys, you get a signal with the sum of the two keys.
If you have any good schematics please post them.
BobTPH
Joined Jun 5, 2013
11,651
What do you want it to do when you press two keys?
I suppose you would use some kind of double pole switch that would disconnect, say, all the lower keys from the circuit when any key is pressed. This would mean that the higher key would always be the one that is sounding when two keys are pressed.
Bob
Surgent Gaming
Joined Feb 26, 2018
Lets say I press the A key. The keyboard emits a CV for A. If I then press the G key without letting the A key go, it will jump to the G key. The CV also jumps to G.
Cheers :)
Brevor
Joined Apr 9, 2011
297
The old analog synths used to work like your keyboard, they gave the sum of the keys pressed. Some newer keyboards work like you want yours to but they use a microcontroller to do the process.
RichardO
Joined May 4, 2013
2,270
You could try a 1N4148 signal diode is series with each key. A Schottky diode would probably work better but you can start with the 1N4148 to see what happens.
Post the schematic of your circuit for a more complete answer.
KJ6EAD
Joined Apr 30, 2011
1,581
The traditional method uses a scanned matrix. Here's a link to one tutorial. You may find others.
http://blog.komar.be/how-to-make-a-keyboard-the-matrix/
Monophonic "lead" synthesizers still use this method even though they're not polyphonic. They typically have logic that prioritizes either the last key pressed or the lowest note pressed, depending on the trigger or gate setting, when more than one key is held down simultaneously. See page 29 in this manual for one example.
http://cdn.roland.com/assets/media/pdf/SH-101_OM.pdf
