Antique words and phrases
cmartinez
Joined Jan 17, 2007
8,814
Yogi Berra Quotes:
1. “It’s like deja vu all over again.”
2. “We made too many wrong mistakes.”
3. “You can observe a lot just by watching.”
4. “A nickel ain’t worth a dime anymore.”
kv:)
And I believe he once said to an ill friend of his "you dead yet?"
LDC3
Joined Apr 27, 2013
924
Yogi Berra Quotes:
kv:)
When you come to the fork in the road, take it.
Joined Nov 30, 2010
18,224
Encyclopedia.
Touche!
I'm going to work on replacing the radiator in my van today. One hour in and I only have 2 pipes left to remove. It's going well. Nothing seems horribly stuck so I can't get it loose. This reminds me of a phrase that I have never heard from anybody under 30 years old: "I'm going to work".
Update: 4 hours later and all I have to do is put the tools away, add water, and see if it leaks.
GopherT
Joined Nov 23, 2012
8,009
Ok, not that old but much talked about, many dollars and hours of preparation and ultimately a non-event with many names -
Y2K problem,
the Millennium bug,
the Y2K bug,
or simply Y2K
LDC3
Joined Apr 27, 2013
924
Touche!
I would thought that it would be better to see if it leaks before putting the tools away. :oops:
Joined Nov 30, 2010
18,224
Other methods work better. If I had put antifreeze in it immediately, that would assure a leak, so I ran it with just water for the rest of the day. A mile and a half to just barely open the thermostat, then a complete cool down, and three hours later I topped off the water and did forty minutes for a good heat soak. It's on the back porch right now. Absolutely perfect! Not a spare drop anywhere! And, tomorrow it gets antifreeze. I'll just run it a half a mile to get the particles circulating before I dump the water.
Meanwhile, the Chevy 2500 van behind the shed got sold for $5,000 and that's out of my hair.
All in all, a very good day! :)
I'm tired, a bit sore, but nothing unusual in my physical reactions to working. I'll probably regret this tomorrow, but that's normal, too. :rolleyes:
