AlbertHall
- Joined Jun 4, 2014
- 12,663
The diodes around the AND gates make them remember the high input, and that is passed along the string of gates. If you press any other key it clears that memory and you would have to start again with the correct sequence.The original schematic looks like buttons 1-4-7 have to be held down together, no pressed in any particular order. There is no memory element involved to remember that the 1 was pressed before the 4, for instance.
