Analog to Digital Conversion Process
helmi58
Joined Feb 22, 2016
16
Hi! If I would like to discretize a noisy analog sine wave signal with Vpp = 20 mV and 28 kHz (as attached) which way should do it for better result? What are the important considerations? This signal is received from an electret hydrophone located about 10 cm from the source. This signal have to be discretized before processing in 3.3V operating FPGA.
Method 1
1. Amplify
2. Filter
3. ADC
OR
Method 2
1. Filter
2. Amplify
3. ADC
Which one better?
What type of ADC is suitable?
cmartinez
Joined Jan 17, 2007
8,854
Method 1
1. Amplify
2. Filter
3. ADC
OR
Method 2
1. Filter
2. Amplify
3. ADC
Which one better?
How much resolution do you want? 8-bit, 16-bit?
bertus
Joined Apr 5, 2008
23,000
It depends.
Amplifiers can also introduce noise.
I have attached a PDF with some filter design topics.
I also have attached a PDF on opamp basics.
And a PDF on filters in combination with ADC's.
helmi58
Joined Feb 22, 2016
16
It depends.
It depends on what? Any factors to be considered? I'm considering using AD743 op-amp, with noise of 2.9 nV/√Hz at 10 kHz.
helmi58
Joined Feb 22, 2016
16
It depends on the used components.
Resistors and opamps can introduce noise.
The choise you made for the opamp is a good one.
You might also want to have a look at the LT1028:
http://www.linear.com/product/LT1028
For the resistors use metalfilm and not carbon resistors.
Thank you for your valuable feedback. Should i split the gain for filter and amplifier or filter with unity gain?
bertus
Joined Apr 5, 2008
23,000
There are filter circuits that will allow amplification, but amplification will be limited.
Also what kind of filter you had in mind.
For an ADC most times a lowpass filter is used.
See the PDF's I posted earlier.
helmi58
Joined Feb 22, 2016
16
For now i'm thinking of using bandpass filter with a bandwidth of 1kHz centered at 28kHz. I have two option: (1) Using continuous time active filter (opamp based) and (2) Using switched-capacitor. But I'm not really sure about advantage and disadvantage of each method.
helmi58
Joined Feb 22, 2016
16
By the way, some of the PDF you posted earlier I have read before, just I need further explanation and conformation since this my first time seriously work on analog system and ADC.
cmartinez
Joined Jan 17, 2007
8,854
In that case, you have a whole lot of reading to do just yet. PCB design and layout is critical to any "clean" ADC system
22,111
This is one of those complicated tradeoffs. I was thinking you might employ a passive filter which normally has an insertion loss. If your total gain is from 20 mVPP to say 5VPP, that is a factor of 250 or 24 dB. Rather than do this in one stage you could have 2 stages at 12 dB or even 3 stages at 8dB. Each stage would be less likely to oscillate or behave badly and you get the required gain. In the three stage arrangement I would put the filter after the first stage.
OBW0549
Joined Mar 2, 2015
3,565
If I'm not mistaken, a gain of 250 is 44 db, not 24 db. Aside from that quibble, I think your amplify-filter-amplify recommendation is the most practical one. Myself, I'd probably choose an amplifier with a gain of 10, followed by a 30 kHz 2-pole lowpass filter, then another X10 amplifier to feed into the ADC.
22,111
Actually for voltage gain it should be:
\(20\;\times\;log_{10}(250)\;\approx\;48 \;\text dB\)
Since I deal mostly with power gain I was using a factor of 10 -- my bad.
A voltage gain of 100 will get you from 20 mVPP to 2 VPP, which shold be adequate.
