Hello everyone.
I'm working on a project for automatic vegetable growing system and designing a PCB for a device that will have the possibility to measure pH probe readings of water using AD795 operational amplifier.
The thing I'm confused about is the output of the AD759 - the supply voltage is +15 and -15 volts and in the datasheet it sais that the op amp outputs 1V/pH unit. Does this mean I can trust the datasheet and the output is positive voltage in the range of 0-14 volts? I plan to use a voltage divider and then feed the output to an ADC.
Would appreciate any help. I'm not too good at analog electronics and this is the part that is keeping me stuck.
