I will try to explain the issue, hopefully without missing out information
Scenario:
A device (IR sensor) which includes analog and digital circuits is powered by a 24V DC power supply.
The digital and analog grounds are shortened, and wired via 10M + 1u to device's case at a single physical point.
Some time ago all the electrical equipment in the room had to be taken out, due to painting been done.
Issue:
Since the equipment has been reconnected some of the sensors show noises ,from an unclear source, at the
analog channel. These noises appear only when powering up the default device in one room, but not in the next-door room.
Several test done didn't change the result, including using a different power supply, removing all other electrical equipment
at the same power line and removing chassis connection.
The earthing grounding line of the building is being checked every once in a while with no issues found.
At the link below is a zipped folder with two videos of an oscilloscope filming, viewing two points at the device - a dc-motor's feedback digital signal
at the top, and the IR Sensor's measurement point at the bottom. One video includes the noise appearing at the 2nd signal,
and the other without (which is taken in the near-by room).
Mod: Zipped link, removed pending Moderation
I will appreciate any ideas of figuring out what is the source of this noise and how do remove it.
Thanks,
Amitai
Scenario:
Issue:
Thanks,
Amitai
