An explanation is needed for a small alarm system
AlwaysNumber1
Joined Dec 4, 2016
52
Hey everyone !)
I am new in the area of electronic engineering and I am currently designing a circuit of a small alarm system. Although everything works well, I still need to ask the following questions for a clearer understanding:
1. Why do we need 2k2 resistor ?
2. Why is the loudspeaker jointed to the collector of a transistor ? (as by my logic it should be the collector)
Have a good day !)
AlbertHall
Joined Jun 4, 2014
12,653
1. To limit the current flowing through the grey transistor and the base/emitter of the black transistor otherwise the transistors would be destroyed.
2. I assume you mean you think the speaker should be in the emitter of the transistor?
The emitter and collector provide roughly equal current gain, but the collector provides voltage gain where the emitter does not so the power available to the speaker is greater.
AlwaysNumber1
Joined Dec 4, 2016
52
Thanks so much for your reply !!
AlwaysNumber1
Joined Dec 4, 2016
52
But in this circuit there is no resistor for the collector6 though th transistor is the same and the voltage is twice greater...
