An easy to build resistor box.
Wendy
Joined Mar 24, 2008
23,805
I had an idea how to build a resistive box that won't break the bank,bought 2 packs of 1Ω 5% 5W resistors and 10Ω 5% 5W resistors. The rest will be 1/4W 5% carbon resistors here is the proposed schematic I haven't started building it yet :
the smallest increment is 1 ohm the largest is 19 MΩ. When I get to that point I will print a 3D box for it and post it here.
SamR
Joined Mar 19, 2019
5,526
I have a couple of these. I couldn't buy the parts for what they sell them for. Only 1% resistor instead of high precision but good enuff for most of what I do. They use standard dual pin jumpers instead of switches.
35,021
I have a variety of resistance boxes.
The two I use mostly are this Model 236A from Phipps & Bird,
and this variable twin pot I made from two 10k 10-turn pots with digital knob,
Wendy
Joined Mar 24, 2008
23,805
Why buy when you can build. I use 5 watts for the lower resistances because I was thinking of power supply loads.
Jerry-Hat-Trick
Joined Aug 31, 2022
839
I’m thinking, the cost of switches is typically high compared to the cost of resistors and whilst selecting the right switches in a binary fashion will allow you to select any resistance you want the simplicity of a conventional rotary switch arrangement has a lot going for it
