Amplify digital tv antenna signal with class A amplifier possible?
38,827
At that frequency it isn't getting the right components that's the problem, it's placing them properly on a circuit board with a good ground plane using the proper RF layout techniques.
Otherwise you're just spinning your wheels.
18,168
I thought I'd find a take-apart of one of the commercial TV antenna amplifiers from Mohu, RCA or others, but I was surprised that nothing showed up. I'm not in the mood to tear mine apart, so no reverse-engineering.
Reloadron
Joined Jan 15, 2015
7,949
That was my drift in post #8. Now if you look at the transistor data sheet from the transistor cited in post #20 mounting it will be a truly entertaining experience. :) So while building can be a educational and rewarding experience sometimes a man has to know his limitations.
Ron
circuitfreak2000
Joined Apr 7, 2015
39
Thanks for all the great info. Manhattan style circuit construction is something I am familiar with. I did manage to build a FM transmitter before, that connects to my smartphone and let's me hear music on a frequency 95 - 105Mhz on the radio in the car. It worked pretty good :) I know these can be bought for a few bugs, but the joy of having constructed one yourself is just awesome.
Bertus posted some great options to build a UHF amp, especially this one looks simple and promising.
VHF/UHF amplifier with MAR-3
There is 5Volt Ucc power supply. The gain is about 12dB in all television bands (50-800MHz). The current to MAR-3 is about 35mA. NF=6dB. IP3=23dBm. The maximum output power can be 10dBm (=10mW). The Monolithic amplifier MAR-3.
Does anyone have an idea what L1 is in this circuit?
Perhaps this circuit might perform better Manhattan style?
Somebody else shared the information that tv channels that already come in strong might overload the transistor. What would happen in that case?
bertus
Joined Apr 5, 2008
23,006
The choke can be made with a resistor where about 20 turns of isolated wire around it.
The ends of the coils can be soldered to the wires if the resistors.
bertus
Joined Apr 5, 2008
23,006
At 5 Volts no resistor is needed.
When your supply voltage is higher, use the value given in the table.
circuitfreak2000
Joined Apr 7, 2015
39
Yes, it shows that under "SUGGESTED RESISTOR BIAS VALUE". Makes perfect sense now. You rock! I look very much forward to constructing this circuit and testing it.
alfacliff
Joined Dec 13, 2013
2,458
and that circuit posted in #20 will probably work, the first one you called a class a amplifier has no bias so cant be called class a, also the incoming signal isnt through a capacitor, so the bias will be affected by the circuit before it.
