Amplifier Design / Off-the Shelf
strokebow
Joined Jan 26, 2008
14
I am wondering if someone can help please.
I'm trying to measure a signal which is of the order of microAmps. The signal appears only once for a short duration due to a passing projectile.
The speed of the projectile is 10 - 20 metres per second. I'm using an oscilloscope but need a sensitive amplifier that has a large gain but with high SNR. The gain should be ~1000.
Dodgydave
Joined Jun 22, 2012
11,395
How are you getting the current, what sensor are you using? Can you be more specific about what you're doing, voltage, frequency?
