Amplifier circuit with 555 ic
Copey84
Joined Jul 27, 2015
198
Hi all, need some help with a amplifier circuit that I have built on breadboard but can't seem to get working.
Confident all connections and components are ok, so beginning to think maybe there's a problem with wiring diagram.
I've included the diagram hoping someone could check over it and confirm that it will actually work.
Appreciate any replys, thanks.
12,143
The schematic is too small to read in detail. Also, this isn't an IQ test - what is it you are trying to achieve, and how do you think the circuit is supposed to work?
Hint - why is pin 7 not connected?
Copey84
Joined Jul 27, 2015
198
Thanks for doing that ak resolution on mine is bad, can already see two errors I have made.
Had circuit running on 5 v instead of 9, only had a 680ohm resistor instead of 680k.
Wanted to learn about amplifiers so pulled circuit from internet, got a few others working ok just had problems with this one.
Had thought pin 7 might be an issue, do all pins on a 555 timer ic need connecting?
12,143
Contrary to opinion, this circuit will work (after correction) as an audio amplifier, just not a very good one. But, the tone of you response makes me think that you think this is a "normal" approach. It is not. This is one approach to what is called a Class D audio amplifier, basically a pulse-width modulation (PWM) switching power supply with an output that varies at audio frequencies rather than make a constant DC voltage. There are many other, and mostly better ways to do this if your intent is to experiment with class-D audio. If you just want a simple little amplifier, look for circuits based on the LM386. There are tons.
For a pulse-width modulation (PWM) circuit, pin 7 usually is tied to pin 6, as in the PWM circuit on the 555 datasheet.
BR-549
Joined Sep 22, 2013
4,931
555 AMPLIFIER
The 555 can be used as an amplifier. It operates very similar to pulse-width modulation. The component values cause the 555 to oscillate at approx 66kHz and the speaker does not respond to this high frequency. Instead it responds to the average CD value of the modulated output and demonstrates the concept of pulse-width modulation. The chip gets very hot and is only for brief demonstrations.
Copey84
Joined Jul 27, 2015
198
Thanks ak didn't think it was most conventional way to amplify, still not working.
Replaced 680 ohm resistor with 680k and powered of 9v battery, speaker crackles but nothing else.
Will read up on 555 timers again, even with link to pin 6 and 7 no audio at speaker.
Copey84
Joined Jul 27, 2015
198
Thanks for reply BR-549 still can't get it to work though.
No plans to use it in any project, no now there are better ways to amplify circuits.
Have used a condenser mic, is that ok for this circuit ? The speaker is 8ohm 0.5w
Copey84
Joined Jul 27, 2015
198
Got the amplifier working correctly although the speaker still crackles a bit when talking into mic.
Does the speaker crackle because of the PWM signal, or is it something else?
BR-549
Joined Sep 22, 2013
4,931
It might be because the PWM is getting interrupted. Like being over driven.
Try speaking softly into the microphone.
Copey84
Joined Jul 27, 2015
198
No I have used similar circuit to the one you found fault in, did try building that circuit but didn't work now I know why. The circuit I used is in first post, ak posted a better quality pic of it.
Tried speaking softly into mic still same problem, alot of crackle and hiss, maybe it's becaus its not a very good amplifier. What else would cause crackle and hissing in audio? it's present even when not speaking into mic.
Copey84
Joined Jul 27, 2015
198
Have used the circuit from engineers garage with a link from pin 7 to pin 6, wasnt until I increased voltage to 12v that audio could be heard although there was alot of noise in the circuit.
If I connect 10k resistor to pin 3 as pointed out by OBW will the enginners garage circuit still work, even though the capacitors are not the same size.
By having the 10k resistor connected to positive rail and not connected to pin 3, would this create noise in circuit.
Also how could noise go down with connection of pins 7and3?
BR-549
Joined Sep 22, 2013
4,931
There is a difference between circuit noise and circuit distortion.
There is no use worrying about noise til we see what kind a linearity we can get with your setup first.
We need to see if the input to pin 5 is driving the frequency change out of the linear range.
Do you have a scope? I have not seen a 555 configured that way. I am wary.
