The minimum Vout can NEVER go below the negative power supply rail, which in your case is ground (zero volts). 5mV is pretty close to zero. The minimum possible output should be independent of the gain.Hey Ron,
The Vout won't go lower than 5mV when G=5, no resistor, is that normal?
You have to adjust the offset as follows:
With no strain on the gage, adjust the output offset beginning at some positive voltage, then reduce it toward zero until it just barely stops changing, i.e., just to the point where you can see that it will go no lower. If you turn the pot farther, with no change in the output, you have effectively added a negative offset to the input, which is not what you want.
