It means you and your family are about to die a horrible death.What does the red light on my ground mean?
It is both a visual and tactile indicator alerting the home owner of a potential hazardous condition. Visual in that it can be viewed by a person with basic normal vision; and for those with visual impairment using the sense of touch will indicate a fault condition. There is a third indicator for those who may fail to check these conditions on a regular basis and that's the sense of smell. This new indicator is also capable of producing an odor detectable to those who neglect checking systems on a regular basis. It is purposely designed to smell like a burning home. However, at that point it's usually an indicator that a major fault has occurred and the homeowner needs to take immediate action to protect life and property.
I did come across a similar situation with a friend for whom I had done some electrical work on their house. She called quite unhappy that all at once the new outlets had quit working, and also the refrigerator was not running. So I went to investigate, and started checking outlets. Then I asked if there were any more, because the breaker was on and I had not found any problem. She said Yes, one more behind the microwave oven, but it sparks. Indeed. When her kitchen walls were tiled, the crew had removed the outlet and when they put it back there were 3 wires under one screw. And this was the first outlet in the string. The outlet was burned in half, and the wire insulation was burned off for a couple inches, and the wallboard had heat damage. Fortunately there was enough wire to cut off the damaged part and use an adequate wire nut to make a proper connection, adding a lead for the outlet connection. The very heavy duty wire nuts have been an adequate fix for two years now and so she is happy. But that one certainly could have had a worse ending if the wall had ignited.It is both a visual and tactile indicator alerting the home owner of a potential hazardous condition. Visual in that it can be viewed by a person with basic normal vision; and for those with visual impairment using the sense of touch will indicate a fault condition. There is a third indicator for those who may fail to check these conditions on a regular basis and that's the sense of smell. This new indicator is also capable of producing an odor detectable to those who neglect checking systems on a regular basis. It is purposely designed to smell like a burning home. However, at that point it's usually an indicator that a major fault has occurred and the homeowner needs to take immediate action to protect life and property.
Some operators of this sort of warning light have reported an auditory indication that has been described as a crackling sound similar to that of pine logs in a fire. Experts suggest that if any of the above issues are discovered it is advisable to dial your local emergency number and have the issue investigated at once.
I actually found such an indicator in a Chevy Geo, a car that was GIVEN to me. At night you'd turn the lights on and most often they'd come on. However, sometimes you had to step on the clutch pedal to get the lights to full brightness. One evening after dinner I started the car but the lights wouldn't come on at all. So like any GOOD man, I opened the hood and saw a bright white indicator on the radiator cross bar. Like a fool I touched it. Yup! It was indicating a fault for sure. After I was done swearing I tapped it with a pair of pliers and the lights came on. Drove the car home and the next day I re-terminated ALL the body grounds. This one bright indicator was the last ground point to rust out and fail. So I've both seen and touched this sort of indicator. Although admittedly it never made any crackling sounds, nor did it smell like a burning house. That Geo was the worst car I've ever owned. Fortunately I didn't BUY it. The previous owner felt pretty much the same way I did about it.It is both a visual and tactile indicator
Copper is a wonderful conductor of current and also a wonderful conductor of heat. Tony, you are fortunate to have found that when you did. My wife's cousin was not as lucky and as a result of some poorly done work had to replace a large part of her house.Back story on the wiring: There used to be a two bulb ceiling fixture that were rated for two 60W bulbs. The previous owner put two 100W bulbs in the fixture. This is what happened. The insulation was so brittle that I actually cut my thumb on some of the insulation. Just moving the wires around resulted in flaking of the insulation - exposing copper and making ripe conditions for a fire. Leave alone the fact that there could have been an electrical fire, I've had to patch the drywall because it too was scorched.
Now it's the LED's that get damaged with the heat. Using a LED not properly rated for an enclosed space guarantees a short service life.All that has changed with LED so it's a new ballgame now
Yes, and a fixture rated for 60 watts is running 100 watts. Something starts to give, like where the wire is connected to the terminal. Than that junction begins to warm up and the resistance starts to increase. Then like a downhill snowball the problem grows over time. The AWG 12 copper wires start conducting heat away from the source and down the wires. This is how fires start and it is also why the NEC is fussy about how overhead lighting fixtures are placed. Nobody wants to smell smoke in their home.200 watts divided by 120 VAC = 1.67 amps. The wire is 12 gauge. Certainly not done because of excess current. No, it was due to those incandescent bulbs in a poorly insulated light fixture that cooked the wire insulation over time. No telling how long it would have continued to last if the old fixtures were not replaced with pendant and fluorescent fixtures.
Dear Folks,
I saw the on Quora today - pix of electrical connections done by amateurs... thought you all would get a kick out o
Remember AG fuses for automobiles? I recall that one fellow needed something in a hurry. The "something" turned out to be a .22 Short. If he had used a .22 Long that had been fired all would have been well,,,,,,,,,,,he didn't
I always try to follow a general rule. I use ammunition as ammunition and fuses as fuses. Fuses never will work well as ammunition and using ammunition as a fuse simply is not a good idea.Done by Mythbusters. Busted. https://go.discovery.com/tv-shows/mythbusters/videos/gun-cartridge-fuse-minimyth
Has anyone seen nails instead of fuses? Many times myself.I always try to follow a general rule. I use ammunition as ammunition and fuses as fuses. Fuses never will work well as ammunition and using ammunition as a fuse simply is not a good idea.
Ron
