MaxHeadRoom
- Joined Jul 18, 2013
- 30,815
At least no one is likely to get killed with that error.My humble contribution with a PIC 18F.
In many parts of India, the people are too poor to have electricity installed, often the answer is to find a friendly local electrician and bung him a couple of Rupee's for him to run an extension cord off a nearby pole!Yikes!!!
I wonder how much that job pays. With any luck, he might be able to save enough so his family can afford to pay these folks when their services are needed:
That was the way it was done, in the days of tube and knob house wiring.the insulation stripped off and the black wire skinned and wrapped, then soldered,
Been there and fought that, told the lady that I was not trying to be scary, but that she REALLY needed smoke detectors in every room.Wish I had photographed some of the gaffs in my home. Lamp cord in the wall to a switch and desk lamp. A light over the fireplace that was wired (the hot) to a feed to a plug - the insulation stripped off and the black wire skinned and wrapped, then soldered, THEN (the neutral) wired to the leader that goes to the next plug - the insulation stripped off the white wire, skinned and wrapped, then soldered. Hot and Neutral, both from different lines (same leg), soldered and taped up with black tape.
No where near the engineering level of the opening photos. But on that note - even the anti-trip 20 amp breaker, wouldn't it still trip internally? If so, resetting it would be a nightmare. Especially if it controlled the light over the breaker panel.
ALA post #38!For got to say, the soldering was probably done using a "soldering copper" heated in the flame of a gasoline powered blow torch. Like this -
| Thread starter | Similar threads | Forum | Replies | Date |
The Digital Library of Amateur Radio and Communications | Off-Topic | 1 | |
| J | Simple circuit - equivalent impedance - amateur question | General Electronics Chat | 3 | |
Amateur radio license renewal... | Off-Topic | 4 | |
| B | Amateur trying to fix a dead Xiaomi phone | Technical Repair | 7 | |
Amateur radio what to study? | Off-Topic | 1 |
