Alternative transistor to BD139 I can get from Maplins
Jake2
Joined Apr 4, 2012
4
I am doing an Arduino project. The design specifies a BD139 transistor.
http://www.discountelectronicsstore...standard-bipolar-npn-power-transistors-bd139/
To avoid paying £3 postage on a 50p transistor, I'd like to get this at Maplins. Unfortunately, the very nice and helpful guy at the shop says he knows all about resistors, capacitors, and diodes, but not about transistors. So he couldn't help.
Can anyone tell me which transistor in the Maplins catalogue is equivalent to this BD139?
Jake2
Joined Apr 4, 2012
4
I want to control a motor from the arduino. The circuit is in the "30 Arduino Project for the Evil Genius" (Pg 133, in case you have that book) - so I don't have an electronic copy of it.
Here is another design for controlling the motor, which I could use.
http://luckylarry.co.uk/arduino-pro...th-potentiometer-and-multiple-power-supplies/
This one suggests a TIP120 transistor - which I also can't find at Maplins.
Basically, I am a teacher (maths, so no knowledge of electronics) and am trying to build a prototype robot which I can then guide some students through (secondary school). So any simple design would be fine - that doesn't cost too much!
Jake2
Joined Apr 4, 2012
4
Thanks for that, and for the amazingly quick responses.
The Arduino generates 5V from its pin. Should I be able to use one of these as an alternative to the BD139 and the TIP120 in the circuit? i.e. to control the current to the motor?
bertus
Joined Apr 5, 2008
23,027
In the show project in the link, a 1K resistor is used between the arduino pin and the base of the transistor.
The shown alternative transistors will work with this value too.
