I'm looking for a smaller alternative to a DPDT relay.
It's going to be used as a switch to connect two USB devices to a single USB-Port of a PiZero or C.H.I.P.
The Devices will be used separately, one at a time.
Heres how my Setup would look like using a DPDT relay:
USB Device A:........USB Device B:........PiZero/C.H.I.P:
+Data = A1.............+Data = B1..............+Data = C1
-Data = A2..............-Data = B2...............-Data = C2
Both devices are powered from a separate source, so only -Data & +Data are connected to the DPDT.
To switch between the devices the relay will be triggered by the GPIOs using python.
(A USB-HUB is not an option because it's not simple enough and oversized.)
A DPDT relay would work but they're huge and I need something really small.
I just don't know how to find what I'm looking for other than asking here, so thank you in advance!
