Aliens at last?
BR-549
Joined Sep 22, 2013
4,928
If I had just developed a new stealth tech.....and needed/wanted to deploy it overseas(NK for instance)....I would first test it by intruding on the best commercial and military response system I could find.
Would it be possible to fly airspace that is monitored by about 6-7 militaries?
It could have been drug dealers headed north. The major Narcos have the resources to buy Russian radar countermeasures on the black market and outfit a commercial size aircraft for a one time use. I heard them say there was also troposcatter that day so maybe their 'cloak' was not totally effective on commercial radar.
The report 'is' from the Threat study investigation. If anyone truly believed this was a 'real' alien craft the study would still be under the 'black budget'. As you can see inside the report most people make jokes about these types of incidents (they happen a lot but don't make the news) instead of serious investigation. I think there was a serious program to see if we could reproduce what most believe are electromagnetic energy transmission altering atmospheric conditions (a naturally occurring Metamaterial of water vapor/crystals and thermal layers) to make 'Foo Fighter' type radar and sensor effects but I don't know if anything became of it. I believe it's another case of nature doing what's possible in physics long before we discover it's possible.
cmartinez
Joined Jan 17, 2007
8,872
Thing is, for ordinary people at least, Occam's razor would point at aliens, and not some more "complicated and hard to explain" natural phenomena... But yes, for the more scientific type, natural phenomena is the first thing to look for, even if it's explanation is a little convoluted for pedestrian tastes... ball lightning comes to mind, it wasn't until recently that a more or less reasonable explanation has been developed for this sort of thing.
There are other 'good' videos of AAV craft from reliable sources.
https://arstechnica.com/science/201...-chilean-officials-cant-explain-ufo-sighting/
After this sighting, the Navy turned the video over to the the Committee for the Study of Anomalous Aerial Phenomena, known as CEFAA. This is the Chilean government group that investigates UFO sightings, or Unidentified Aerial Phenomenon. On Friday, after a study by scientists, military officials, and even some photo analysis experts from France, the committee released its conclusion.
"The Committee for the Study of Anomalous Aerial Phenomena, comprised of leading scientists, analysts, and aviation technicians, after an extensive study of the case, determined that it was a UAP, or Unidentified Aerial Phenomenon," the agency stated in a news release.
As I've said before, during the Cold War both sides aircraft saw them, sometimes filed reports about them and joked about them.
killivolt
Joined Jan 10, 2010
836
I've found this Wood Cut very interesting. https://en.wikipedia.org/wiki/1561_celestial_phenomenon_over_Nuremberg
Also one over Switzerland.
wiki said:
" A military interpretation would view the tubes as cannons and the spheres as cannonballs, emphasize the black spearhead at the bottom of the scene, and Glaser’s own testimony that the globes fought vehemently until exhausted.
I would like to note now that I found that people viewed round objects "exiting" tubes which sounds exactly the same as my cousin claimed he seen.
kv
Edit: This is his claim from post #329
Ray said:
He then claims to have seen another one, when he was a child, only this one was the Cigar shaped type, he said it hovered this time over the south side of Utah Lake while these on Monday were on the North Side and it opened up on one side and 3 shining objects came out one by one. He claimed he could see windows along the side one went above another down below and the last went out to the front, then they hovered he said for sometime, then the bottom one went in then the top one, the opening closed and it then streaked up and away, but the last object went streaked North at the same altitude and Vanished.
ArakelTheDragon
Joined Nov 18, 2016
1,366
People are like ants, they can not understand, that the Earth itself is also alive and that makes it an alien, despite that it exists differently from what people accept as normal.
wayneh
Joined Sep 9, 2010
18,178
“The idea that other universes might exist arises from the realization that the Big Bang might not have been a unique event but a common one. ”
Might? How arrogant, anthropomorphic, and blind to our own history of science does one have to be to think we’re in the only Big Bang bubble in the froth of foam in the ocean that is the real Universe with a capital U, not just “the universe” that we have so arrogantly called our little niche.
Most of these multi-verse theories spring from string theory/M-theory and the extra spatial dimension math (10 or 11 dimensions that's very useful in things like deep learning) needed to make it work. The problem is there is zero real evidence string theory is THE theory (all tests so far about predictions beyond the standard model have failed at LHC or at any advanced experimental apparatus like LIGO) and the number of possible string theories is estimated to be something like one followed by five hundred zeros. It predicts anything, everything and nothing beyond other Quantum Field Theories . String theory isn't wrong or right, it is simply a frame work.
https://www.math.columbia.edu/~woit/wordpress/?p=9375
The problem with this is that there is no sign of any possibility of progress towards deciding if the string theory landscape implies low-energy SUSY or not (quite the opposite). If you give up the assumptions of SUSY and 10/11 dimensions, you give up what little hope you had of any connection with experiment. She doesn’t mention the LHC at all, especially not the negative results about supersymmetry and extra dimensions that it has produced. The significance of these negative results is not that they disconfirm a strong prediction of string theory, but that they pull the plug on the last remaining hope for connecting standard string theory unification scenarios to anything observable. Pre-LHC string theorists could make an argument that there was good reason to believe in electroweak-scale SUSY, that such a scenario fit in well with string theory unification, and that LHC discovery of SUSY would point a way forward for string theory unification. That argument is now dead. All that’s left is basically the argument that “maybe a miracle will happen and we’ll be vindicated” which in her version is:
In principle one could test string theory locally. In practice, this would require discovering a smoking gun signature (such as a low string scale at colliders, or perhaps a very distinctive pattern of primordial perturbations in cosmology), and nothing particularly favors such scenarios currently.
RichardO
Joined May 4, 2013
2,270
[QUOTE="nsaspook, post: 1273969, member: 59115"It predicts anything, everything and nothing beyond other Quantum Field Theories . String theory isn't wrong or right, it is simply a frame work.[/QUOTE]
