after automotive lead acid battery charger circuit
turbo1600
Joined Jan 12, 2016
7
i have a transformer rated at about 10A, anybody have a simple type charger circuit for auto batteries ? i have a lm395k if thats any help.
Alec_t
Joined Sep 17, 2013
15,160
I have an ancient battery charger with a similar output voltage from the rectifier. The only things between the rectifier and the battery are an ammeter and a length of resistance wire. One of these days I must get round to adding some smarts to the charger :).
38,913
If by simple, you mean a dumb charger, than you could just use a full-wave bridge rectifier and some resistance to limit the maximum charging current.
It also needs a fuse or circuit breaker to protect against accidental shorting or reverse connection of the output.
Note that this simple configuration will likely overcharge the battery if the charger is left connected past the battery fully-charged point.
dl324
Joined Mar 30, 2015
18,491
I could see that this would be a worthwhile project if you couldn't buy a charger, or thought you could do a better job than commercially available chargers. Personally, I'd buy one for $30 and do something more interesting.
A good charger will take more than a power transistor. You need to regulate the voltage and you also need to use different voltages.
https://batteryuniversity.com/index.php/learn/article/charging_the_lead_acid_battery
mvas
Joined Jun 19, 2017
539
If you like to build things ...
Here is a "very simple" 5 Amp ( 12 Amps Peak ) Battery Charger ...
https://www.electroschematics.com/5465/fast-charger/
It shows a CT Transformer, but you can use your transformer and a Full Wave Bridge.
I would replace D3 with a 10 Amp Vf=0.25v Schotky Diode.
Set the Voltage to 14.8 Volts then connect your battery.
A large car battery ( 75 Ah ) is done when the current falls to 2 amps or below
A small car battery ( 454 Ah ) is done when the current falls to 1 amp or below
Disconnect the battery when done.
I would buy a ( $15.00 ? ) Adj CV/CC 10 Amp Buck Converter from ebay and connect it to the xfmr & bridge rectifier.
turbo1600
Joined Jan 12, 2016
7
hi, that looks more like it, thanks, but how can it be 5amp if d3 is rated at only 3A.
mmmmok.. looks like i screwed up , i meant a LM396K voltage regulator, NOT lm395k.. sorry..
38,913
Yes, D3 should be rated for at least 125% of the maximum charging current.
That can be substituted for the LM338 with no other circuit changes.
Below is the LTspice simulation of a simple battery charger circuit using the LM338 (or LM396) with an added current limiter.
Transistor Q1 turns on to reduce the output voltage, and thus the current, when the voltage across shunt resistor R4, due to the charging current, ≈ 0.65V at typical charging voltages.
The current limit is thus about 0.65V/R4.
The output voltage charging limit is determined by R1 (gives a value of about 14V for the value shown).
D1 prevents damage to the circuit if the battery is accidentally reverse connected (output pulled negative).
D2 prevents damage if the battery is connected without input power.
The simulation shows the battery voltage (simulated by a large capacitor) going from 10V to 14V (blue trace) with a charging current of around 4.5A (yellow trace).
Note the dissipation of the regulator (red trace) shows that it needs to be on a large heat-sink.
Edit: I just noticed that the LM396 has a maximum in-out voltage rating of 20V, so could fail for a reverse battery connection, which could put up to about 30V across it.
You could protect against that by putting a power diode from output to ground (anode to ground) with a fuse between that and the output.
That would blow the fuse for a reverse connection.
