I have a 10k thermistor circuit that is part of a low power 3.3V design and I would like to implement a switch IC to enable/disable the 10K thermistor circuit power via an MCU. Below is the schematic of the circuit I am attempting to power on or off. Can you help recommend an IC to accomplish this?
Would this be sufficient for a low powered application:
771-HCT1G66GV125
single analog 3.3v switch
https://www.mouser.com/datasheet/2/916/74HC_HCT1G66-1597748.pdf
771-HCT1G66GV125
