Not hard at all. In fact, it's one of the easiest of digital filters to implement aside from straight summation.It is the first time I have heard about the boxcar filter so I will need to look it up first as it does seem a bit involved & not sure how I could do this in my code.
When I eyeball your graphs, I see spurs. So you still have noise injection somewhere -- therefore the data is not as good as it could be -- but it may be good enough for you. You decide. Post the data and let me look at it.But with this set up am I not quite close to the full 17.4 bits noise free at 10 sps and 15.9 noise free bits @80 sps.
(I get p-p 303 codes and 114 codes which are 17.16 and 15.76 noise free bits). Does that mean most of the noise is coming from the bridge sensor? since that is the only thing I have replaced ?
I haven't used pots and transistors in a decade. I prefer the integrated digital approach. There are others here who enjoy dabbling in such novelties. They'll show up if you post the right questions.If you have any recommendations of how the circuit/schematic might need to look like or what types of pots and transistors to use...
