Adjustable pulse speaker
Alec_t
Joined Sep 17, 2013
15,149
Welcome to AAC!
Without knowing the internal circuitry used to generate the pulses it's unlikely you will be able to add anything to adjust the pulse rate upwards; but an external circuit could be used to switch the buzzer on and off periodically, thus reducing the long-term average pulse rate (albeit inelegantly).
BobTPH
Joined Jun 5, 2013
11,609
It is not clear in the ad whether the pulse rate is adjustable or not. It would be odd to have one with a fixed pulse rate that might be 2 or 7 pulses per second.
In any case, a simple 555 circuit could be used to turn the continuous tone into an adjustable pulsed tone.
Bob
ScottWang
Joined Aug 23, 2012
7,504
The buzzer didn't mention that how to control the pulse rate, so only can assuming that it is control the voltage 1 - 13Vdc, so you can use 555 cmos type to build a pwm circuit with 12V and the output add a diode and capacitor to do the rectifier and filter job.
If the 555 output current is not enough for the buzzer the you can add one stage of BJT or MOSFET.
